Hello.
I have OH3.1.0. (2100) under Windows 10 (20H2)/Chrome, I5-4690T, 8Gb RAM and SSD SATA3 128 Gb; Java runtime Zulu 11.
I use the following physical things/bindings:
- Zwave dimmers and switchs through Aeotec Z-stick USB Gen5
- Somfy blinds, awnings and rollersshutters with RTS and IO motors through Somfy Tahoma
- Tado Termostat and radiator controllers through Tado/Wifi
- Air conditioning through Melcloud/wifi
- Other bindings like Astro, Kodi, upnp, etc
I am still some like a beginner, with no previous experience with the exception of OH3.
Some days ago I tried to uninstall Orvibo binding and install Dark Sky binding in main UI but I couldn’t do. I repeated the operation some times with no success. These are the displayed messages during operations:
Unistalling Orvibo binding: “Uninstalling…” (indefinitely)
Installing Dark Sky: “Installing…” (indefinitely)
I have read in a community post that a solution could be switch off the “Access Remote Repository” option in Settings/Add On Management, but I had no success again when installing or unisntalling again.
As I saw in another post, I have also checked the config file “Addons” at C:\OpenHAB310\userdata\config\org\openhab. It contais this:
:org.apache.felix.configadmin.revision:=L"34"
binding=“http,melcloud,somfytahoma,upnpcontrol,zwave,astro,kodi,weatherunderground,tado,darksky”
misc=“openhabcloud”
package=“standard”
persistence=“rrd4j”
remote=B"false"
service.pid=“org.openhab.addons”
ui=“basic,habpanel”
So according this file, Orvibo has been removed and Dark Sky added…
OH3 keeps working normally with all the things installed and rules created but I can’t change nothing in the add-ons section. Or perhaps there are changes but I can’t view them.
Could somebody give instructions to try to solve the problem?
Thank you in advance
Diego
