@pail_frank23
I am new with openHAB. I want to get to know the system and use it in my private household. I have products from myStrom, also Bulbs.
I saw that you have developed the binding for myStromg. I wanted to ask if you also plan to implement the Bulbs.
If not, I would be interested in doing the further development myself. I am already a Java developer, but I still have to learn a lot about openHAB.
Thanks for a feedback.
open an issue on GitHub for that binding. The developer may not be on this user forum.
@fredo It would be great if you could submit a PR with the implementation for the bulb. I don’t have such a bulb and therefore I don’t intend to implement it in the binding. The implementation should be straightforward based on the implementation of the plug. Thanks a lot for your contribution.
I there a possibility to add the mystrom “button” to the offical binding?
I want to excange my so long used shelly button’s with the mystrom button.
But the buttonis not listet in the binding.
I want try start “rules” in Openhab via the button.
So the is a need that the Button is litest as a thing and has channel to use, line the shelly button has.
Thanks in advanced.
Hello. I’m sorry, but I no longer use OpenHab, so I won’t be able to develop anything here.
I hope someone else will take it on.
Good luck!
