I had issues with my git branch so I made a new clone. Since then I am not able to continue developing my binding as it does not appear in the Main UI/Things/Bindings.
I even made a clean install of Eclipse in Windows deleting .m2 folder .p2 folder. I am running Eclipse on a Windows machine with JavaSE-17.
My console output when I start is:
! 10:40:12.081 [INFO ] [org.openhab.core.Activator ] - Starting openHAB 4.0.0 (build Unknown Build No.)
10:40:13.706 [WARN ] [ce.jetty.internal.JettyServerWrapper] - Can't create temporary directory for OsgiContextModel{HS,id=OCM-17,name='context:1275119693',path='/',bundle=org.apache.felix.webconsole,context=WebContainerContextWrapper{bundle=org.apache.felix.webconsole_4.7.2 [50],contextId='context:1275119693',delegate=org.apache.felix.webconsole.internal.servlet.OsgiManagerHttpContext@4c00c84d}}: C:\Users\chris\AppData\Local\Temp\ROOT\context:1275119693
10:40:19.262 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'demo.items'
10:40:19.877 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
10:40:20.220 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'demo.sitemap'
10:40:20.450 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'demo.things'
10:40:24.052 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'demo.rules'
10:40:34.076 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
10:40:34.114 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'DemoLocation' changed from NULL to 52,9
10:40:34.115 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'DemoContact' changed from NULL to OPEN
10:40:34.116 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'DemoString' changed from NULL to Hello SmartHome!
10:40:34.117 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'DemoDateTime' changed from NULL to 2023-03-26T10:40:34.071038400+0200
10:40:34.127 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'DemoNumber' changed from NULL to 12.34
The Binding is linked in the pom.xml of the demo.app like this
<dependency>
<groupId>org.openhab.addons.bundles</groupId>
<artifactId>org.openhab.binding.sonnen</artifactId>
<version>${project.version}</version>
<scope>runtime</scope>
</dependency>
I have added it in the app.bndrun, resolved it and saved it.
No clue why it isn’t working anymore.
Any hints?
