Hi, i figure out how whe can capture button is pressed ? it is possible in standard mode or whe need to use CEN or CEN+ ?
Also can whe intercept the push ring action when we push the button on the videophone on the front door ? for exemple light out “ON” when someone ring the videophone(Btcino videophone)?
thanks a lot for your help
