nope
do you also use OH2? because maybe the Binding is not compatible to OH2 at the moment
It is working with 1.83 runtime installation without modifications. There are some preparation for OH2 but itās not tested yet.
Iām using raspbian 8 on RP2.
I am running ubuntu on RP3 with OH2 incremental built.
Any plans to make it somewhat compatible?
I have to look why itās not working. What kind of error did you get?
The āRequire-Bundle: org.slf4j.api errorā was fixed, right?
no, was not fixed by installing libslf4j-java through apt-get.
It is the same error obove
Itās the Logger. I will take a look to it.
Looks like the server plugin is missing. Loog here:
/usr/share/openhab/server/plugins
is there something like this:
org.slf4j.api_1.7.2.v20121108-1250.jar
This file is part of:
openhab-runtime: /usr/share/openhab/server/plugins/org.slf4j.api_1.7.2.v20121108-1250.jar
Take a look for this:
http://docs.openhab.org/developers/development/compatibilitylayer.html
There is a compatibility package. You can try it in such way. It will not work out of the box.
Do you really need OH2?
I will take a look to it but it will take some time.
Yes I would like to stick to OH2.
I will try out the compatibility package.
There is no such file nor a folder matching under openhab2.
Strange is that I am already using some non-oh2 bindings.
Are you using some special stuff?
No, all stuff is usuall.
I looking now myself whether it works with OH2.
There is some documentation, like that:
http://docs.openhab.org/tutorials/migration.html
Ok, I found it. It was only a suboptimal configuration. Try this:
Thanks, I will try it out this evening.
I have another question:
I am not understanding this stament
There a two ways of de-/encryption password handling:
With the finished private key, here is this one required:
km200:PrivKey=0000FFFFEEEEDDDDCCCCBBBBAAAA999988887777666655554444333322221111
--OR-- the binding is creating the key from the md5salt, the device and the private password. Here are all three required:
km200:MD5Salt=111122223333444455556666777788889999aaaabbbbccccddddeeeeffff0000
km200:GatewayPassword=AAAABBBBCCCCDDDD
km200:PrivatePassword=MYPASSWORD
I do not have a problem putting in the password in ākm200:PrivatePasswordā. Are the MD5Salt and GatewayPassword as they should or am I missing the point.
What stands GatewayPassword for, do not remember to set such one.
The gateway password is this one from the device (sticker, without the ā-ā). But I dontāt think we should explain it here in detail because there are already much informations on other sites. Take a look the symcon haustechnik forum (KM200 thread) or the FHEM KM200 wiki page and the development thread. There is all this stuff explained.
Hi Markus,
i have enabled the compatibility Layer but i still have the same error with your new jar file
2017-01-16 13:06:36.884 [ERROR] [org.openhab.binding.km200 ] - FrameworkEvent ERROR - org.openhab.binding.km200
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.km200 [175]
Unresolved requirement: Require-Bundle: org.slf4j.api
at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
Maybe i do anything wrong, so please wait for Slavisaās reply
Seems to load now:
2017-01-16 09:38:13.940 [INFO ] [.binding.km200.internal.KM200Binding] - Activated
Hi Slavisa Lukic,
can you please share your steps to activate that binding with me, because it does not work inside my configuration ![]()
ok forget it, i just downloaded the jar file again and the binding start now ![]()
Unfortunately I got an error at the end
2017-01-16 14:31:07.191 [INFO ] [b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/system/appliance/gasAirPressure;0.0;;;
2017-01-16 14:31:07.197 [INFO ] [b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/flameCurrent;0.0;;;
2017-01-16 14:31:07.204 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler, id=273, bundle=9/file:/usr/share/openhab2/addons/org.openhab.binding.km200-1.9.0-SNAPSHOT.jar]: Unexpected problem updating configuration org.openhab.km200
java.lang.NullPointerException
at org.openhab.binding.km200.internal.KM200Device.listAllServices(KM200Device.java:190)[9:org.openhab.binding.km200:1.9.0.201701152210]
at org.openhab.binding.km200.internal.KM200Binding.updated(KM200Binding.java:194)[9:org.openhab.binding.km200:1.9.0.201701152210]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.ConfigurationManager$UpdateConfiguration.run(ConfigurationManager.java:1772)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109)[3:org.apache.felix.configadmin:1.8.12]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_111]
any guess things still will work?
the binding is loaded:
openhab> config:list | grep km200
Pid: org.openhab.km200
BundleLocation: file:/usr/share/openhab2/addons/org.openhab.binding.km200-1.9.0-SNAPSHOT.jar
service.pid = org.openhab.km200
openhab>
