Thanks! Seems that I have missed that. Will set DEBUG level and reboot to have the complete startup process in the log!
Cheers and a HAPPY NEW YEAR!!!
Hello Justus, yes, can be that all parameters are aligned to the devices in the system. I will answer to that in the other post.
How I got the list: I enabled the debug mode (Openhab console) for the binding, disable and enable it in the WEB Frontend and all the entries where logged to the openhab logfile. Afterwards I delete a few info lines. I copied all lines with the services in the text file.
Hi Markus,
thanks, Iâll do that. In addition a few more insights to the rest of the colleagues here. Configuration/Devices of my heating system.
Heating system itself with 2 heating possibilities 1 Line goes normal to the rooms and 2nd line to the so called Hotwaterstation (Frischwasserstation). In addition there is a solar system, the KM200 Gateway and the Logamatic RC310.
We build the system in a special: Both pipes (Hotwater and Heating) are connected to buffer tanks and not the hole house or to the hotwaterstation. With that configuration Iâm able to use my own programs to bring the consumption of the energy down to the lowest point. Because I"m able to steer now against the weather forecast and the difference between the target room temperature and the temperature in the pipes.
The only thing I need to do, is to steer these two values in the Buderus System from external.
Hallo Helmut,
I took a look to your logfile. Your device is reporting one heating circuit (hc1), one supply (hs1), one hot water circuit (dhw1) and one solar circuit (sc1). The set values are inside this things. Now some details:
DHW1:
There is a parameter for the current operation mode (operationMode) inside of the water circuit dhw1. The values are Off|low|high|HCprogram|ownprogram. The current value is âhighâ, it means that the heating system is always using the âhighâ value (in the night, too). In this dhw1 thing is that the âhighâ channel, that is set to 50 °C. The sensor value hotWater_t2 is 51.8 °C, but the actualTemp in dhw1 is 21.2 °C, this is strange⌠in my system they are same.
HC1:
There is a parameter for the current operation mode (operationMode) inside of the heating circuit hc1. The values are auto|manual. The current value is âmanualâ. The heating system is maybe using in this case the manualRoomSetpoint value as target for the room temperature, 21 °C.
The heating system calculates a supply temperatur (depening on the outside temperature or room temperature sensor and the choosen room temperature). In your case itâs calculated (supplyTemperatureSetpoint) to 41 °C, the current temperature is (actualSupplyTemperature) 32.5 °C. This regular curve is set inside the controller, you can change this in the service menu, but maybe itâs not used because youâre in manual mode. (No Idea what is happen in this case exactly).
I think that your heating system is designed to calculate the needed supply temperature by its own. Thatâs maybe the reason why itâs read only. I would configure the regular curve for the supply temperature in the service menu of the heating system (depending on outside temperature or room temperature sensor) and let it go in automatic mode. For me it works nice. Take a look to it.
You could set some manual calculated offsets with the roomTempOffset parameter, this could be enough.
Greetings
Hello Markus,
all around the DHW1 works as described - thanks for your time and explanation. Unfortuanetly all around the HC1 doesnât work very well in my case.
Fist of all the parameter list: In case I switch the operation mode from manual to automatic - the parameter list changed an the manual room setpoint is gone. That means the list is dynamic.
In case I leave it on the status manual, Iâm able to change the manualRoomSetpoint, this is fine. Also this writen back to the RC310 and Iâm able to see it there. I think this value is used to steer the mixer of âVorlauf/RĂźcklaufâ to bring to the right temperature. Unfortunaetly the heating cuircit itself heats up always until the temp max volume of the central unit is reached. For sure the mixer brings it down to the right level. This is OK, the rooms are directly connected.
In my case there is a buffer between, so I have to influence max volume of the heat appliance itself. Unfortunaetly it looks like there is no way to steer it.
Thx.
Helmut
Hello KM200 community. Since the 2.5.1 update (Docker), my KM200 binding installation is not working anymore. I donât know if it had something to do because I removed snapshot from /addonsâŚ
I tried clearing the cache, uninstall the binding etc.
I saw that in 2017 there was a similar issue: âhexString needs to have an even lengthâ - Binding Request : Buderus web gateway
I tried to install the custom addon again and configure it, but same result.
14:34:17.413 [ERROR] [est.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at 'things/km200:kmdevice:f326bbc6/config'
java.lang.IllegalArgumentException: hexString needs to have an even length:
at org.eclipse.smarthome.core.util.HexUtils.hexToBytes(HexUtils.java:105) ~[?:?]
at org.eclipse.smarthome.core.util.HexUtils.hexToBytes(HexUtils.java:119) ~[?:?]
at org.openhab.binding.km200.internal.KM200Device.setCryptKeyPriv(KM200Device.java:151) ~[?:?]
at org.openhab.binding.km200.internal.handler.KM200GatewayHandler.dispose(KM200GatewayHandler.java:145) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.handleConfigurationUpdate(BaseThingHandler.java:104) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.updateConfiguration(ThingRegistryImpl.java:93) ~[?:?]
at org.eclipse.smarthome.io.rest.core.internal.thing.ThingResource.updateConfiguration(ThingResource.java:438) [bundleFile:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_232]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_232]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_232]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_232]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [bundleFile:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [bundleFile:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) [bundleFile:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) [bundleFile:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) [bundleFile:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [bundleFile:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [bundleFile:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [bundleFile:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [bundleFile:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [bundleFile:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [bundleFile:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [bundleFile:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [bundleFile:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [bundleFile:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [bundleFile:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
Please update your post to âmy bindingâ or âmy KM200 installationâ. As my KM200 binding is working perfectly every day with the latest testing release âthe KM200 binding is not working anymoreâ seems to be wrong.
Updated.
I am on openhab 2.5.2 and I cannot seem to get the km200 binding to work.
The private key should be correct. I generated it myself and compared it to the one generated via the link you find on the net, they are the same.
Yet I get this error when starting up:
An error occurred while calling method 'ThingHandler.dispose()' on 'org.openhab.binding.km200.internal.handler.KM200GatewayHandler@59b3cc': hexString needs to have an even length:
2020-03-22T14:15:30+01:00 homectrl karaf[11122]: java.lang.IllegalArgumentException: hexString needs to have an even length:
2020-03-22T14:15:30+01:00 homectrl karaf[11122]: #011at org.eclipse.smarthome.core.util.HexUtils.hexToBytes(HexUtils.java:105) ~[bundleFile:?]
2020-03-22T14:15:30+01:00 homectrl karaf[11122]: #011at org.eclipse.smarthome.core.util.HexUtils.hexToBytes(HexUtils.java:119) ~[bundleFile:?]
2020-03-22T14:15:30+01:00 homectrl karaf[11122]: #011at org.openhab.binding.km200.internal.KM200Device.setCryptKeyPriv(KM200Device.java:151) ~[?:?]
2020-03-22T14:15:30+01:00 homectrl karaf[11122]: #011at org.openhab.binding.km200.internal.handler.KM200GatewayHandler.dispose(KM200GatewayHandler.java:145) ~[?:?]
2020-03-22T14:15:30+01:00 homectrl karaf[11122]: #011at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_152]
2020-03-22T14:15:30+01:00 homectrl karaf[11122]: #011at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_152]
2020-03-22T14:15:30+01:00 homectrl karaf[11122]: #011at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_152]
2020-03-22T14:15:30+01:00 homectrl karaf[11122]: #011at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_152]
2020-03-22T14:15:30+01:00 homectrl karaf[11122]: #011at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
2020-03-22T14:15:30+01:00 homectrl karaf[11122]: #011at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
2020-03-22T14:15:30+01:00 homectrl karaf[11122]: #011at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_152]
2020-03-22T14:15:30+01:00 homectrl karaf[11122]: #011at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_152]
2020-03-22T14:15:30+01:00 homectrl karaf[11122]: #011at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_152]
2020-03-22T14:15:30+01:00 homectrl karaf[11122]: #011at java.lang.Thread.run(Thread.java:748) [?:1.8.0_152]
2020-03-22T14:15:30+01:00 homectrl karaf[11122]: 14:15:30.368 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while disposing handler of thing 'km200:kmdevice:home': hexString needs to have an even length:
The key is 64 char long.
Any Idea how I can further debug this or what the problem might be?
Looking at the function this error was raised it seems it expects a â-â delimited key, though that doesnât work either.
It looks like the key is not 64 characters long - otherwise it had an even length. Yours must be 63, 65 or another uneven number. Use BBEdit or anything else to count the characters. Hope my interpretation is correct.
Unfortuantely as I noted the key is 64 chars long.
I fixed my problem⌠I was acutally missing the JCE part of zulu jre ⌠unbelievable one still has to install that manually -_-
Thanks I did that and it works fine now
I have a problem with the km200 binding that has been working really well for the last 8 months but after I updated to 2.5.3 release build it stopped working. I use it with the Junkers version of the box but as it has worked before it should work now as well
I have my openhab running on a Qnap system within a docker container. Within PaperUI I get the error âUNINITIALIZED - HANDLER_INITIALIZING_ERRORâ for the Gateway thing.
Within the logs I get this error and I really do not know what else I can do to make it work again: 16:54:43.191 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method âThingHandler.initialize()â on âorg.openhab.binding.km200.internal.handler.KM200GatewayHandler@185638f0â: null
at org.openhab.binding.km200.internal.handler.KM200GatewayHandler.checkConfiguration(KM200GatewayHandler.java:240) ~[?:?]
at org.openhab.binding.km200.internal.handler.KM200GatewayHandler.initialize(KM200GatewayHandler.java:114) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_232]
16:54:43.196 [ERROR] [.core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing âkm200:kmdevice:617200032â: null
Does anybody have a suggestion ?
Hello @Markinus,
small suggestion from my side: It would be beneficial if we had a sticky post at the beginning of the thread showing
Currently I´m not certain if 2.5.3 contains the fixes from November or if it is even more advanced.
From what I see in the log the fix for the decimal digits has not been included in 2.5.3 yet.
This would make live much easier when deciding to e.g. remove the âBugfix-Versionâ from the AddOns folder and go for âstandardâ again.
Kind Regards and stay healthy
Oggerschummer
for those struggling with the invalid hex string length let me provide the steps I took to resolve it.
Inititial situation:
I had a snapshot version of the binding installed in the add-ons folder of OH 2.5.x. (The last one mentioned in the thread above)
After upgrading to 2.5.2 and 2.5.3 many channels did not appear anymore.
So I decided to drop the snapshot version and go for the one included in 2.5.3.
Deleting the snapshot file did not help, as after activating the 2.5.3 version in the PaperUI the infamous âeven-lenght-errorâ occured.
In the end I came up with this solution:
sudo openhab-cli clean-cache
from console to clear the cache.Most important I guess is to drop any remaining entries / files from previous version and to clear the cache.
Hope this helps, it reproducibly did the trick for me.
Stay healthy
Oggerschummer
I havenât changed anything on this binding. The last precision fix is not merged yet.
For me the binding works perfectly after the update to 2.5.3. One thing what I am always doing after a upgrade is to stop openhab and clean the cache ( sudo openhab-cli clean-cache
) and reboot the device. This is fixing many problems automaticaly on upgrade.
Greetings
Markus
@Markinus, @Oggerschummer, @Truercki,
I had the same problem but I found the issue ⌠In my case I was not using the right cryptography level. I am running the docker container version of OpenHAB and you can set a runtime variable for the security which can be âlimitedâ or âunlimitedâ to support higher encryption. And in the previous container I had the variable set but forgot to set it in the new container again. Once I corrected that it works now like expected
think I have found a way to reproduce a situation where the key-length error shows up:
When you have a running installation (mine now worked for one day without trouble),
go to Paper UI, edit the gateway and set the auto refresh intervall from 30 seconds to 60 seconds.
As soon as you save it a HTTP 500 Internal server error shows up. In the log it complains about the invalid key lenght (even if is was working flawlessly just seconds before.)
2020-04-07 16:47:42.997 [ERROR] [st.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at âthings/km200:kmdevice:817210159/configâ
The binding did not recover from this without a restart.
After I restart OH the binding is running again, but did not save the auto refresh rate (stayed at 30).
Trying it again results in the same crash.
Maybe this gives a hint where there might be a bug - maybe the handling of the parameter data (read/write) of the gateway thing has an issue.
Greetings
Oggerschummer
