I would like to set the domestic hot water temperature for my Viessmann heat pump with the binding “SmartHome/J Viessmann”. The binding is connected to the viessmann cloud and can read the values, but not set. In my rule, I do this:
@ChrisM
On my installation, setting the temperature works.
Please PM me from the log in TRACE mode. You can enable the loglevel in the karaf-conlose by typing:
log:set TRACE org.smarthomej.binding.viessmann
@sven1234 your issue has another reason, i’ll try to fix it asap
I tried to dig into this and in my case it looks like the feature heating.dhw.temperature.main requires a setTargetTemperature command which is not handled by the binding.
Many Thanks. I don’t need that at the moment. The fix is mostly complete, but there are some adjustments to the created channels. I want to avoid deleting the thing and having to recreate the channels. I’ll get to work on the implementation tonight.
