Hi Community,
since some days my open hab can’t set a connection with my blink account.
Following error message come in my blink bridge thing: “Blink Account not set in bridge”.
java.io.IOException: Blink Account not set in bridge
at org.openhab.binding.blink.internal.handler.AccountHandler.getCameraState(AccountHandler.java:323) ~[?:?]
at org.openhab.binding.blink.internal.handler.AccountHandler.getTemperature(AccountHandler.java:379) ~[?:?]
at org.openhab.binding.blink.internal.handler.CameraHandler.handleHomescreenUpdate(CameraHandler.java:197) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:183) ~[?:?]
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195) ~[?:?]
at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:177) ~[?:?]
at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1655) ~[?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484) ~[?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173) ~[?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]
at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:497) ~[?:?]
at org.openhab.binding.blink.internal.handler.AccountHandler.fireHomescreenUpdate(AccountHandler.java:391) ~[?:?]
at org.openhab.binding.blink.internal.handler.AccountHandler.loadDevices(AccountHandler.java:275) ~[?:?]
at org.openhab.binding.blink.internal.handler.AccountHandler.refreshState(AccountHandler.java:254) ~[?:?]
at org.openhab.binding.blink.internal.handler.AccountHandler.lambda$1(AccountHandler.java:258) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
By trying to login my bridge, I don’t receive any verification PIN. Only by delete and recreate of blink bridge thing is a verification possible. After some times its go again lost, no additional verification with the same thing is possible - I don’t receive any verification PIN.
Do you have any Idea, what the problem it can be?
many thanks in advance, Sergo
