Blockly AktuelleZeit als SS:mm
Is there is block to get the current time in a user defined format ?
You can get the time with now-block and then create these strings Date-String but your not completely free in the format.
But when you look at the code, it generates the following for you
(zdt.now()).format(dtf.ofPattern(‘yyyy-MM-dd’));
So what you could do is use the inline-script-block and manually create that little snippet youself with the wanted pattern.
Does that help?
Thanks, I couldn’t figure that out as well and went with hour and minutes of
 but this gives you a number. So this would be 7:3 if it’s 07:03 which needs more formatting.
(zdt.now()).format(dtf.ofPattern(‘HH:mm’));
works. Thanks again.
Works pefectly. Only issue is size of inline box. This is far to small. So it is very hard ti edit the text.
I know but I haven’t found any way to (re)size the box in the past where I have seen the same, though I tried just now with the latest blockly version on 3.4.x:
Does it look different on your side. Can you show meyour block with some blocks around, so I can try to reproduce it?
Maybe I’ll add something like “with Pattern” (and input box) to that Block in 4.0 :wink:
Would you like that?
Definitely! That would be perfect.
Is this the same topic?
