Processor : Intel® Core™ i5-8250U CPU @ 1.60GHz
Memory : 7912MB (3090MB used)
Machine Type : Desktop
Operating System : Ubuntu 18.04.4 LTS
java version
openjdk version “11.0.1” 2018-10-16 LTS
OpenJDK Runtime Environment Zulu11.2+3 (build 11.0.1+13-LTS)
OpenJDK 64-Bit Server VM Zulu11.2+3 (build 11.0.1+13-LTS, mixed mode)
OH version openHAB 2.5.2 Release build
I do have zwave and other device working ok. But the Bluetooth binding has a error.
"2020-03-20 06:22:25.229 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.initialize()’ on ‘org.openhab.binding.bluetooth.bluez.handler.BlueZBridgeHandler@5e5a3849’: Cannot access BlueZ layer.
java.lang.IllegalStateException: Cannot access BlueZ layer.
at org.openhab.binding.bluetooth.bluez.handler.BlueZBridgeHandler.initialize(BlueZBridgeHandler.java:104) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor49.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
Caused by: java.lang.RuntimeException: Native library is out of date. Please update the native library.
at tinyb.BluetoothManager.getBluetoothManager(BluetoothManager.java:317) ~[?:?]
at org.openhab.binding.bluetooth.bluez.handler.BlueZBridgeHandler.initialize(BlueZBridgeHandler.java:92) ~[?:?]
… 9 more
2020-03-20 06:22:25.271 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing ‘bluetooth:bluez:4a712fb1’: Cannot access BlueZ layer.
… 9 more
Any suggestion to fix this ?
Thank you
