Unless I’ve misunderstood something, it seems the Bluetooth binding only reports change in rssi. If two consecutive readings of rssi report the same value, only the first result would trigger a change or update rule. If this is true, you can’t reliably know the last detection of presence of a BLE beacon. You can’t tell the difference between a beacon reporting repeatedly the same rssi from a beacon that left the house.
Does this sound familiar to anyone? Did anyone create some kind of work around, perhaps some kind of Exec binding with a script doing some hcitool lescan for detecting presence of a ble beacon?
I created my own BLE device presence control, it’s been extremely reliable during the week I’ve been using it. It makes use of the Exec Binding and a linux script doing some hcitool lescan, leaving a Switch On or Off. Together with a Network binding that detects when my phone register on my local network I’ve got a flawless Home/Away setup.
var Number lastPresenceActivity = now.millis
// BLE Tile is scannable => I'm home
rule "PresenceActivityTileScan"
Item LescanRaw received update "1"
if (AtHome.state != ON) AtHome.sendCommand(ON)
// Check every 5 minutes for last AtHome event, 10 minutes with no activity sets away
rule "PresenceCheck"
Time cron "0 0/5 * 1/1 * ? *"
if (AtHome.state != OFF && now.millis - lastPresenceActivity > 600000) { // 10 minutes
AtHome.sendCommand(OFF)
The Network Binding makes sure the AtHome switch sets to ON when I’m in Wifi range and disarms the alarm before I open the door. The lescan script makes sure the switch stays ON even though the phone goes in sleep mode, is turned off, out of battery, etc. My BLE device is a “Tile Mate” on my keys.
