Ok it’s working with the parameter in the Things file thx
Just noticed your screenshot above, this is not 3rd party binding. It is really confusing, the bindings are called the same.
anyone still have problem that RSSI (showing -66) value doesn’t change at all? Even bluetooth thing added without any issue?
I’m using official bluetooth biding on RPI3 with BlueZ 5.47.
Thx
Y
yes!
Same issue, things and items correctly created, the items linked to the rssi channel showed -77 as first value, when the item was created, and no any update from then. The things is configured on an iPhone.
openHAB 2.4 stable, BlueZ 5.43, Raspi 3B
I am using current master version of openhab 3 on RPI3.
My problem is that after adding found Bluetooth ‘Things’ they are always online. Only way of taking them offline is by disabling and then re-enabling the Bridge. This way, Things will come online again ONLY if they are present nearby.
I’ve tried changing the beacon times in bridge advance settings to small numbers but made no difference.
How can we have the Things Online/Offline status update continuously and automatically?
Thank you.
