- Platform information:
- Hardware: CPUArchitecture/RAM/storage
Pi 3B+ - OS: what OS is used and which version
Docker - Java Runtime Environment: which java platform is used and what version
Docker - openHAB version:
2.4.0-armhf
- Issue of the topic: please be detailed explaining your issue
Hi I run openhab in a raspberry pi docker in privileged mode and try to use it’s internal Bluetooth with the binding but had no luck…has anyone tried a similar setup, also encountering problems?
- A: Do you run the docker in networkmode = host?
- B: Have you tried using bluetoothctl to see if it can see your devices? you need to verify bluetooth is working on host OS first
A: yes
B: yes the Bluetooth is working on host
I currently use raspberian lite as host
Anyone with a solution/same issue?
Indeed. the same config (hardware/software), the same issue with no working bluetooth.
My fix was to stop use docker for open hab and go back to host installed software what i do not prefer now.
regards
m.
Same issue here, on openhab 2.5
Also still the same here…
Any news on this?
Edit: I moved this to development, as I don’t know if the issue still exists in OpenHab 3…did someone test this? If it’s working we can mark a solution here
