I am currently working on getting the presence detection via bluetooth ping to work. I used this tutorial: https://klenzel.de/3328
I’ve got /scripts/bt.sh with this code:
#!/bin/bash
#1=Tobias, 2=Theres
case $1 in
1) MAC="60:F4:45:XX:XX:XX" ;;
2) MAC="11:22:33:XX:XX:XX" ;;
esac
if /usr/bin/l2ping -c 1 $MAC &> /dev/null
echo "ON"
else
echo "OFF"
fi
when I am using the raspberry console it is working pretty well:
[12:04:39] openhabian@openHABianPi:~$ sudo ./scripts/bt.sh 1
ON
The problem is that it is not working when I am using the same command via user openhab:
[12:09:06] openhabian@openHABianPi:~$ sudo -u openhab ./scripts/bt.sh 1
OFF
I already edited the visudo, as you can see here:
[12:11:15] openhabian@openHABianPi:~$ sudo -u openhab sudo -l
Matching Defaults entries for openhab on openHABianPi:
env_reset, mail_badpass, secure_path=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
User openhab may run the following commands on openHABianPi:
(ALL) NOPASSWD: ALL
I think that the problem is l2ping. As sudo it is working well, but it is not as user openhab.
I just have no idea how to change this, as giving openhab complete sudo rights (I know that I should restrict them later on), did not change anything.
Does anyone have an idea?
