mightypolo
(Pavel Hrudka)
September 26, 2016, 3:33pm
1
Hi.
I came across this product .
It should be bluetooth controllable heating valve.
Also it is quite cheap, cheaper then z-wave units.
Is there a way to integrate it?
I was able to find integration for home assistant only.
I would love to create own thermostat
Cheers!
I wish it would be implemented by someone
I’m giving up with my Danfoss Living Connect (z-wave) thermostats.
They are just not suitable for anyone, who is not going to check them daily if they have lost connection and in panic state and need to be reset again.
vzorglub
(Vincent Regaud)
March 13, 2018, 2:09pm
3
There was some work done to control these via bluetooth with an arduino.
It seemed to be working but the code needs work to make it more flexible
https://github.com/xavriley/Arduino-EQ3-Motion-Aware-Radiator-Thermostat
I looked into these but then decided to go with thermal actuators and sonoffs:
Hi all,
I’m sharing with you here my heating setup in the hopes that it can help someone (and to just show it off, too, I guess.
My house is quite typical of UK houses, where I have a boiler, and one or more radiators in each room. The boiler is on/off only, and has a single thermostat, usually located in the worst possible room in the house. You then end up with a single thermostat controlling the temperature of the whole house. I had basic thermostatic valves on each radiator, but the overal…
Good luck
