featboi
(Daniel)
September 14, 2023, 11:26am
1
Good morning,
I’m currently relatively new to Openhab.
I have currently connected some Shellys and Philips HUE lamps via “mosquitto2mqtt”.
Now I have bought 6 Bosch Thoermosatet (BTH-RA) and have already integrated them.
I can already control the target temperature.
I have problems displaying the actual temperature and the battery. No values are shown to me here.
Can someone help me with this?
Thing
Thing mqtt:topic:******:Thermostat_Esszimmer "Thermostat_Esszimmer" (mqtt:broker:*******)
Channels:
Type number : temperature "Raum Temperatur" [ stateTopic="zigbee2mqtt/Thermostat_Esszimmer/local_temperature" ]
Type number : setpoint "Gewünschte Temperatur" [ commandTopic="zigbee2mqtt/Thermostat_Esszimmer/setpoint-temperature", formatBeforePublish="{ \"occupied_heating_setpoint\":\"%s\"}", transformationPattern="JSONPATH:$.occupied_heating_setpoint" ]
Type number : battery "Batterie" [ stateTopic="zigbee2mqtt/Thermostat_Esszimmer/battery" ]
Item
Group Thermostat_Esszimmer "Thermostate_Esszimmer" (Esszimmer) ["HVAC"]
Number:Temperature temperature "Esszimmer_Temperatur [%.1f °C]" <temperature> (Temperature, Thermostat_Esszimmer) ["Measurement", "Temperature"] { channel="mqtt:topic:******:Thermostat_Esszimmer:temperature" [scale="Celsius"] }
Number setpoint "Esszimmer_Setpoint [%.1f °C]" <temperature> (Thermostat_Esszimmer) ["Measurement", "TargetTemperature"] { channel="mqtt:topic:******:Thermostat_Esszimmer:setpoint" [scale="Celsius"] }
Number:Dimensionless batterie "Esszimmer_Batterie [%d %%]" <battery> (Battery, Thermostat_Esszimmer) ["Battery"] { channel="mqtt:topic:******:Thermostat_Esszimmer:battery" }
Thank you =)
Best regards
FeatBoi
hmerk
(Hans-Jörg Merk)
September 14, 2023, 12:17pm
2
Welcome to our community!
In order to help you, we need to see the raw mqtt messages for the missing values.
At first sight seems that incoming transformation is missing.
featboi
(Daniel)
September 14, 2023, 12:49pm
3
Thanks for trying to help.
I Hope i got the right messages.
"battery": 100,
"boost": "OFF",
"child_lock": "UNLOCK",
"display_brightness": 7,
"display_ontime": 10,
"display_orientation": "normal",
"displayed_temperature": "measured",
"linkquality": 184,
"local_temperature": 19.4,
"linkquality": 188,
"local_temperature": 19.5,
"local_temperature_calibration": 0,
"occupied_heating_setpoint": 18,
"pi_heating_demand": 0,
"remote_temperature": 0,
"running_state": "idle",
"system_mode": "auto",
"update": {
"installed_version": 889525524,
"latest_version": 889525524,
"state": "idle"
"update_available": false,
"window_open": "OFF"
hmerk
(Hans-Jörg Merk)
September 14, 2023, 2:01pm
4
Not really, your channel definition shows individual topics for local_temperature and battery, but the message you posted shows a JSON response including them all.
Question is, does the device publish all values as individual topics, then you need to sho the messages published on them. if not, what‘s the topic you posted the message from?
featboi
(Daniel)
September 14, 2023, 2:40pm
5
I got only this message from my MQTT Explorer.
Sry, but i am a beginner at this moment
Where can i find the relevant topic?
hmerk
(Hans-Jörg Merk)
September 14, 2023, 2:45pm
6
Ok, even this is completely not openHAB related, lets try to sort this out.
Can you post a screenshot from MQTT Explorer, so we can try to find out what topics the device publishes to.
Or even better, do you by chance have any mqtt documentation for the device?
featboi
(Daniel)
September 14, 2023, 3:12pm
7
Thanks for your help.
You can find a documentation on the following link “https://www.zigbee2mqtt.io/devices/BTH-RA.html ”
Exactly output:
zigbee2mqtt/bridge/logging {"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/Thermostat_Esszimmer', payload '{\"battery\":100,\"boost\":\"OFF\",\"child_lock\":\"UNLOCK\",\"display_brightness\":7,\"display_ontime\":10,\"display_orientation\":\"normal\",\"displayed_temperature\":\"measured\",\"linkquality\":124,\"local_temperature\":19,\"local_temperature_calibration\":0,\"occupied_heating_setpoint\":18,\"pi_heating_demand\":100,\"remote_temperature\":0,\"running_state\":\"heat\",\"system_mode\":\"heat\",\"update\":{\"installed_version\":839193876,\"latest_version\":889525524,\"state\":\"available\"},\"update_available\":true,\"window_open\":\"OFF\"}'"}
hmerk
(Hans-Jörg Merk)
September 14, 2023, 3:28pm
8
Found that documentation in the meantime.
Seems, everything id published at one topic, so please try
Channels:
Type number : temperature "Raum Temperatur" [ stateTopic="zigbee2mqtt/Thermostat_Esszimmer", transformationPattern="JSONPATH:$.local_temperature" ]
Type number : battery "Batterie" [ stateTopic="zigbee2mqtt/Thermostat_Esszimmer", transformationPattern="JSONPATH:$.battery]
featboi
(Daniel)
September 14, 2023, 5:07pm
9
perfectly. It works =)
One more question. The percentage value of the battery is given as 10000. How do I get it calculated to 100?
hmerk
(Hans-Jörg Merk)
September 14, 2023, 5:23pm
10
I think the channel type is not correct, don‘t know a battery type. Try to set it to dimensionless too.
featboi
(Daniel)
September 14, 2023, 5:25pm
11
I got it. The itemtype is now only “number” not “Number:dimesionless”.
Thanks a lot for your help =)
Have a great day =)
hmerk
(Hans-Jörg Merk)
September 14, 2023, 6:13pm
12
And you!
Please mark this topic as solved…
