Regardless of the situation in BountySource, make sure to file a feature request issue on the openhab-addons repo. That’s going to be required no matter what I think.
I’m currently in the process of getting the binding up to the latest OH version and ready for a PR. I’ve also implemented the write parts, so that certain settings can be updated.
Let me know what you need and I’ll try to add this into the next version. I’m hoping to get it out within the next 3 weeks (after Easter holidays).
Wow, an answer from the man himself Thank you.
This is great news.
I don’t need anything special other than the ‘write parts’ to set the charging mode.
I only discovered that the six CT readings are numbered the wrong way around; as in from 6 to 1 instead of 1 to 6. See [myenergi] MyEnergi Binding - #9 by Max_G
Happy to test if required.
And am also happy to part with the money I had in mind as a bounty or buy coffee or whatever makes you happy (or is useful / appropriate).
Thank you all for chipping in some ideas how it all works, as I didn’t know that either.
And a reply from BountySource just popped in:
Hi Max,
Thank you for reaching out!
You can create an account in the meantime with Github!
Best regards,
Team Support
