peterd
(pd)
July 2, 2016, 3:52pm
#1
I have several Fibaro FGK101 in place and work fine. Now I bought another one and after inserting (zwave binding 1.8) it shows the following entry:
There is no Configuration section, furthermore, the sensor doesn’t react to the magnet (move to and remove from the sensor, no blue led blinking).
I already changed the sensor with my dealer, but the new one shows the same behavior.
Many thx in advance for your hints…
Peter
chris
(Chris Jackson)
July 2, 2016, 4:09pm
#2
This device is a new device - see this post -:
Alan_Alberghini:
Greetings, I'm also testing this device but I'm having some issues. I have two FGK-10x sensors: one with the 2.5 firmware and the other with v3.2. While the one with the older firmware works flawlessly, the other one fails to be properly recognized by the zwave binding. During discovery it is being reported as Z-Wave Node 7 (010F:0701:1001:3.2) and then no channels nor properties pop up in the thing configuration. The version of the zwave binding I'm using is 2.0.0.201607010102. Should I open an…
