After changing log level setting in mqtt binding via mainui
First i changed from INFO to DEBUG only on this one → org.openhab.binding.mqtt (everything stil working)
When i later wanted to change the settings back everything was set to DEBUG ?
I changed everything from DEBUG to INFO after this logging stopped working, also log levels under every binding was disappeared ?
Spending many hours, reading in here and trying stuff, i found that log4j2.xml had an error i copied an old version from my backups into the system and after everything was back to normal.
Edit running debian 12.5 with openhabian
Openhab 4.1.1 milestone
Do you mind providing a diff that shows the difference of the changes (images are not very helpful because it requires us to find the changes visually)?
