So the trigger will be available in 4.2 I assume? Looking forward to try it!
Blockquote
I think you can do all of this using Persistence Extensions. For example, you could use <item>.averageBetween(ZonedDateTime, ZonedDateTime) - example
I kind of need a time series of time series - in my uses case I keep avg prices between 17-21 in an item (group AVG function), and then I have a history of avg prices between 17-21 in the past days, I then compare if today/tomorrow is more/less expensive to the previous week (so avg of avg prices in the past 7 days). I think even with the time series support, I still need to persist the avg prices, or do I misunderstand how it works?
I wanted to check with you first that this solution would be viable. It seems so, so I will then publish the PR soon and would expect it to be included with 4.2.
In order to be able to access prices for the past 7 days, InMemory persistence will not be sufficient. The binding only fetches and publishes the last 24 hours. However, with another persistence service such as MySQL, you would be able to accomplish exactly that. Not only will it allow you to access the historic and future prices, but it can also calculate average prices for you within requested periods as shown in my example above.
Hi.
Iām looking for some advice on how to calculate if and when itās a good idea to charge my house battery during the night, I hope this thread is a good place for that.
Currently Iām doing this at 22:00 every evening:
ā¦and on the cheapest hour that I get back, I charge my battery (depending also on values returned from solarforecast). This often works very good, since the prices are higher in the morning, so the battery will be charged when the prices are at the lowest. Some days however the prices look something like this:
ā¦which means Iām effectualy charging my battery at one price and then the prices get even lower the next hour. What do I do about this? I mean, I could of course ask for the lowest price the entire next day, but no matter which time period I chose Iāll be risking that the period will be ending with falling prices and the hours after it will be even cheaper. Am I thinking this wrong? How do you others do about things like this?
I think what Iām really trying to achieve is: Get the cheapest hour in this 10 hour period. But only if the hours directly after the period are more expensive. Guess that couldnāt be that hard to achieveā¦
Could the problem be as simple as this: You are looking for the cheapest hour within the next 10 hours (second argument in your rule), so at 22:00 you are only checking prices until 08:00 the next morning?
Yep, thatās correct. And as I said, this mostly works fine, but sometimes (like in the day in my screenshot) the price is going down after 08:00 which makes this problematic. Maybe I need to first check when itās cheapest (like Iām already doing), then check the exact price for that hour and then check if that price is actually lower than the price between say 8 and 12 oclockā¦
I guess I donāt fully understand what you are trying to accomplish then. If you really want to find the cheapest hour, even if after 8:00 the next day, you should simply extend your search, e.g.:
Yep, ended up doing something like that. So it itās even cheaper some time between 8:00 and 11:00 Iāll simply abort the rule completely. Hope this logic will hold.
Itās funny, I thought this would be something that everyone with a house battery would want to do, optimize things like night charging, but I struggle to find any good design patterns for it. Guess it differs so much from user to user that it would be hard to doā¦
Sorry to bother you again but Iām struggling with lots of warnings in my log after upgrading to 4.2. I understand there has been some persistency API changes in 4.2 (good thing I suppose), however I canāt seem to figure out how to workaround the problem.
It looks like the issue is triggered by the following in my rules:
var double stdDeviationWeek = (gEnergiDataServiceTomorrow.deviationSince(now.plusDays(-7)) as Number).doubleValue
var double avgWeek = (gEnergiDataServiceTomorrow.averageSince(now.plusDays(-7)) as Number).doubleValue
var double avgDayPrice = (gEnergiDataServiceTomorrow.state as Number).doubleValue
As I understand it reads all historic states from the persistency service, and the error I have received looks like the following (I have thousands of them when this particular rule is triggered):
2024-07-25 13:00:32.101 [WARN ] [nce.extensions.PersistenceExtensions] - Item gEnergiDataServiceTomorrow is QuantityType but state 1.872597290395115 at time 2024-07-20T22:22+02:00[Europe/Copenhagen] retrieved from persistence has no unit
I have recently (more than a couple of weeks ago) added QuantityType for energy price, however it didnāt give me any issue in OH 4.1. And the definition of gEnergiDataServiceTomorrow is average price of all itās members:
Group:Number:EnergyPrice:AVG gEnergiDataServiceTomorrow "Avg Price Tomorrow [%.2f %unit%]" <price> (gEnergiDataService)
Group:Number:EnergyPrice:AVG gAvgPrice00_06Tomorrow "Avg Price Tomorrow 00:00-06:00 [%.2f %unit%]" <price> (gEnergiDataServiceTomorrow)
Number:EnergyPrice PriceAt00Tomorrow "El Price Tomorrow at 00:00 [%.2f %unit%]" <price> (gAvgPrice00_06Tomorrow, gEnergiDataServiceTomorrow)
Number:EnergyPrice PriceAt01Tomorrow "El Price Tomorrow at 01:00 [%.2f %unit%]" <price> (gAvgPrice00_06Tomorrow, gEnergiDataServiceTomorrow)
Number:EnergyPrice PriceAt02Tomorrow "El Price Tomorrow at 02:00 [%.2f %unit%]" <price> (gAvgPrice00_06Tomorrow, gEnergiDataServiceTomorrow)
Number:EnergyPrice PriceAt03Tomorrow "El Price Tomorrow at 03:00 [%.2f %unit%]" <price> (gAvgPrice00_06Tomorrow, gEnergiDataServiceTomorrow)
Number:EnergyPrice PriceAt04Tomorrow "El Price Tomorrow at 04:00 [%.2f %unit%]" <price> (gAvgPrice00_06Tomorrow, gEnergiDataServiceTomorrow)
Number:EnergyPrice PriceAt05Tomorrow "El Price Tomorrow at 05:00 [%.2f %unit%]" <price> (gAvgPrice00_06Tomorrow, gEnergiDataServiceTomorrow)
If I understand correctly, the warning basically says Iām trying to read historic state from a QuantityType (EnergyPrice), however all values in persistency store are without unit.
The question is: I canāt go back in history to change the values, but is there any way to workaround this issue so I donāt receive tons of warnings?
Many thanks in advance!
java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Looks like the Thing is OFFLINE, and I have noticed it happened 2 times last month (I have a script that alerts me if Thing goes OFFLINE), and it took a long time for it to come back.
Also I donāt seem to have prices for tomorrow, maybe the site is down?
It seems there is some planned maintenance going on currently:
Technical optimizations are scheduled for the 19th of August 2024. You might experience operational disturbances on this date, affecting both the client and the API service. We expect the changes to run smoothly, affecting usage as little as possible.
I should have checked that, sorry to bother you!
Itās a bit strange that maintenance is done during the normal working hours though, will report if the Thing doesnāt get back online
Iām not an expert in this area. The best temporary solution might be adding the GlobalSign root certificate to a Jetty config, if thatās possible. Another solution might be to add it to the OS level certificate store. I donāt know how to do either, and Iām not sure who to ask.
Perhaps @wborn knows something regarding Jetty, or @mstormi might know something about how to āfixā this on OS level (openHABian)?
Copy the certificate into a file (start with and including the line -----BEGIN CERTIFICATE----- and until -----END CERTIFICATE-----), e.g. ~/energidataservice.crt.
Import it into the keystore (password is changeit):
Iām also not expert in this but recall if client complains about certificate there is a way to make https without checking certificate, or am I missing something?
Looking at what HA changed?
That is not a solution, at the best itās a quick workaround to get it working. Not providing the intermediate cert is not good practice and one would hope that theyāre working on it and that it will work again soon. I sent them a mail asking about it, might get an answer
Thanks hope they fix the issue. In the meantime I will try the workaround by Jacob. Iām running it on Docker hope it works (obviously it wonāt work next upgrade).
@laursen : I know itās a hacky solution but would it be possible to add an advance setting in the binding to ignore ssl error for non techy users?
Edit: ok I (almost) made it work - now they banned me due to too many requests. Will report if the issue is solved
COMMUNICATION_ERROR
Too Many Requests
For those who run on Docker, this is the command I used:
And I can confirm by this test that itās now trusted:
That is strange. They allow 50 requests per minute, so I canāt imagine how you surpassed that. The binding will wait one hour IIRC correctly after HTTP code 429 (Too many requests).
