Brink Renovent Excellent 300 air ventilation integration
I have integrated a Brink Renovent Excellent 300 in openhab in order to monitor filter state and control the amount of airflow in the house.
From Brink you get the “Brink Connect” module which allows access to the Renovent 300 via modbus/RS485. I conneced my pi with a USB-RS485 converter to the Brink Connect module.
Here are my things for the Renovent:
Bridge modbus:serial:brink [ port="/dev/ttyUSB0", id=11, baud=9600, dataBits=8, parity="even", stopBits="1" ] {
    Bridge poller air [ start=4008, length=5, refresh=300000, type="holding" ] {
        Thing data holding4009 [ readStart="4008", readValueType="int16", readTransform="JS(divide10.js)" ] // temperature outdoors
        Thing data holding4010 [ readStart="4009", readValueType="int16", readTransform="JS(divide10.js)" ] // temperature dwelling
        Thing data holding4011 [ readStart="4010", readValueType="uint16" ]  // pressure supply
        Thing data holding4012 [ readStart="4011", readValueType="uint16" ]  // pressure exhaust
    Bridge poller actFlow [ start=4027, length=2, refresh=300000, type="holding" ] {
        Thing data holding4028 [ readStart="4027", readValueType="uint16" ]  // flowrate supply
        Thing data holding4029 [ readStart="4028", readValueType="uint16" ]  // flowrate exhaust
    Bridge poller bypass [ start=4029, length=2, refresh=300000, type="holding" ] {
        Thing data holding4030 [ readStart="4029", readValueType="uint16" ]  // bypass position
        Thing data holding4031 [ readStart="4030", readValueType="uint16" ]  // bypass operation
    Bridge poller preHeater [ start=4036, length=2, refresh=300000, type="holding" ] {
        Thing data holding4037 [ readStart="4036", readValueType="uint16" ]  //preheater status
        Thing data holding4038 [ readStart="4037", readValueType="uint16" ]  // preheater power %
    Bridge poller maintenance [ start=4038, length=2, refresh=300000, type="holding" ] {
        Thing data holding4039 [ readStart="4038", readValueType="uint16" ]  // current fault code
        Thing data holding4040 [ readStart="4039", readValueType="uint16" ]  // error message filter
	Thing data holding6001 [ writeStart="6000", writeValueType="int16", writeType="holding" ] // set flowrate
	Thing data holding6013 [ writeStart="6012", writeValueType="int16", writeType="holding" ] // set control mode
Here are my items:
Number	TempSupply            		"Zulufttemperatur [%.0f °C]"    			<temperature>	{ channel="modbus:data:brink:air:holding4009:number" }
Number	TempExhaust       			"Ablufttemperatur [%.0f °C]"    			<temperature>	{ channel="modbus:data:brink:air:holding4010:number" }
Number	PressureSupply            	        "Zuluftdruck [%.0f Pa]"    					<pressure>		{ channel="modbus:data:brink:air:holding4011:number" }
Number	PressureExhaust                    "Abluftdruck [%.0f Pa]"    					<pressure>		{ channel="modbus:data:brink:air:holding4012:number" }
Number	FlowrateSupply			     "Zuluftdurchsatz [%.0f m³/h]"    			<flow>			{ channel="modbus:data:brink:actFlow:holding4028:number" }
Number	FlowrateExhaust			     "Abluftdurchsatz [%.0f m³/h]"    			<flow>			{ channel="modbus:data:brink:actFlow:holding4029:number" }
Number	BypassPosition			    "Bypass [MAP(brinkBypassPosition.map):%s]"    				{ channel="modbus:data:brink:bypass:holding4030:number" }
Number	BypassMode			        "Bypass Betriebsart [MAP(brinkBypassMode.map):%s]"  	 	{ channel="modbus:data:brink:bypass:holding4031:number" }
Number	HeaterMode			        "Vorheizung [MAP(brinkPreHeaterMode.map):%s]"				{ channel="modbus:data:brink:preHeater:holding4037:number" }
Number	HeaterPower			        "Vorheizung Leistung [%s %%]"								{ channel="modbus:data:brink:preHeater:holding4038:number" }
Number	ErrorCode			        "Aktueller Fehler [%d]"						<error>			{ channel="modbus:data:brink:maintenance:holding4039:number" }
Number	FilterNeedsCleaning			"Filter [MAP(brinkFilterState.map):%s]"						{ channel="modbus:data:brink:maintenance:holding4040:number" }
Number	brinkSetFlowrate			"Lüftung Durchsatz [%.0f m³/h]"    							{ channel="modbus:data:brink:holding6001:number" }
Number	brinkControlMode	        "6013 [%s %%]"												{ channel="modbus:data:brink:holding6013:number" }
String 	brinkMode					"Brink Mode"
Number	FlowrateProxy				"Flowrate Proxy"
Some transformations are required:
brinkBypassMode.map:
0=automatisch
1=geschlossen
2=geöffnet
0=initialisieren
1=öffnen...
2=schließen...
3=aktiv
4=nicht aktiv
255=unbekannt
0=sauber
1=verschmutzt
0=initialisieren
1=Aus
2=An
3=Test
255=unbekannt
divide10.js
(function(inputData) {
    var DIVIDE_BY = 10;
    return parseFloat(inputData) / DIVIDE_BY;
})(input)
rules:
import org.eclipse.smarthome.core.types.RefreshType
rule "Brink goes online"
	Thing "modbus:data:brink:maintenance:holding4040" changed to ONLINE
	brinkControlMode.sendCommand("4");  // 4: ventilation flow as per modbus (0: as per Brink appliance)
rule "Release brink"
    System shuts down
	brinkControlMode.sendCommand("0");  // flow control as per Brink appliance
rule "However you want to control airflow amount"
	Item ...
	var Number x
	x= ComputeAppropriateFlowrate()
	brinkSetFlowrate.sendCommand(x)
// refresh more frequently to give better feedback in UI
rule "Refresh after flow change"
	Item brinkSetFlowrate received command
	if (receivedCommand != RefreshType.REFRESH) {
		// Update more frequently for a short while, to get
		// refreshed data after the newly received command
	    var i = 1;
		while((i=i+1) < 20) {
			createTimer(now.plusSeconds(i*5), [|
						PressureSupply.sendCommand(RefreshType.REFRESH)
						FlowrateSupply.sendCommand(RefreshType.REFRESH)
rule "Send mail filter needs cleaning"
    Item FilterNeedsCleaning changed to 1
		sendMail("x@y.com", "Filter needs cleaning", "no text")
sitemap Status:
	Text label="Lüftung" icon="flow" {
			Text item=TempSupply
			Text item=TempExhaust
			Text item=PressureSupply
			Text item=PressureExhaust
			Text item=FlowrateSupply
			Text item=FlowrateExhaust
			Text item=BypassPosition
			Text item=BypassMode
			Text item=HeaterMode
			Text item=HeaterPower
			Text item=ErrorCode
			Text item=FilterNeedsCleaning
Item that is only visible if filter needs cleaning:
	Text item=FilterNeedsCleaning icon="alarm" visibility=[FilterNeedsCleaning==1]
Hello Berndq!
Can you give me a more detailed description or a link from your USB-RS-485 converter. I’m also trying to connect my ventilation system to openhab …
Best wishes, Michael
Hi Michael,
these adapters are cheap and all the same, from the software side of view. Just search the web (or the well known auction house) for USB RS485 adapter. Maybe choose the one with the electrical connectors you prefer to use.
On linux they appear as e.g. /dev/ttyUSB0 you the configure the OH modbus plugin with the respective registers (these depend on your ventilation system)
Does your ventilation system use Modbus?
br
Bernd
Hallo!
Yes, my system supports Modbus. I have a Wolf system (CWL-2-400). The ventilation from Wolf (CWL-2-400) is identical to the ventilation from Brink (Flair 400). The Flair 400 ventilation is the successor to the Brink Renovent Excellent 400. Both the CWL-2-400 and Flair 400 now have the Modbus interface on the main board. The Modbus registers are also identical for the CWL-2-400, Flair 400, Renovent Excellent 400/300.
At the moment I am trying to control the CWL-2-400 via an RS 485 adapter and my Windows 10 PC. I use the CAS Modbus Scanner program. And these adapters:
Unfortunately the CWL-2-400 does not answer. The adapters work. The adapters work with another device that supports Modbus!
br
Michael
This will be much easier to experiment with to establish how to connect to your CWL.
You’d need to get right address, baud, parity, wiring polarity, cable type, etc. here.
Hi Michael
to check the connection try to read values from the device (e.g. flow rate or a temperature). Writing is a bit more complicated.
I did my first tests with modpoll (under linux, mabe it is also available for windows)
Reading the supply air temperature:
[19:45:16] oh@openHABianPi2:~/mbpoll/build$ mbpoll -v -m rtu -a 11 -r 4009 -c 1 -b 9600 -d 8 -p even -1 /dev/ttyUSB0
debug enabled
Set mode=rtu
iGetIntList(11)
Integer found: 11
iCount=1
Set start reference=4009
Set number of values=1
Set rtu baudrate=9600
Set rtu data bits=8
Set device=/dev/ttyUSB0
mbpoll 1.4-8 - FieldTalk™ Modbus(R) Master Simulator
Copyright © 2015-2018 Pascal JEAN, GitHub - epsilonrt/mbpoll: command line utility to communicate with ModBus slave (RTU or TCP)
This program comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it
under certain conditions; type ‘mbpoll -w’ for details.
Opening /dev/ttyUSB0 at 9600 bauds (E, 8, 1)
Set response timeout to 1 sec, 0 us
Protocol configuration: Modbus RTU
Slave configuration...: address = [11]
                        start reference = 4009, count = 1
Communication.........: /dev/ttyUSB0,       9600-8E1
                        t/o 1.00 s, poll rate 1000 ms
Data type.............: 16-bit register, output (holding) register table
-- Polling slave 11...
[0B][03][0F][A8][00][01][06][54]
Waiting for a confirmation...
<0B><03><02><00><1F><61><8D>
[4009]:         31
31 meaning 3.1°C
If this doesn’t work, as rossko57 said, double check the communication parameters: baudrate, parity, stop bits, modbus slave address.
You max also check the status of your open hab items: Are they online? Have you checked to openhab logs? You can increase the log level of the modbus plugin to get more detailed information about the problem. There is some documentation about how to increase the logging in OH. IIRC check the modbus plugin docu, it should state about how to increase the log level for diagnostics.
br
Bernd
I am using the first of your adapters.
Hi Bernd,
thanks for sharing your experience. I was solving the same issue but with Brink Flair 300 unit and your code helped me a lot. The Modbus params and addresses are different from Renovent Excellent 300 and the Brink Modbus documentation for my unit is poor, but after few hours of experimenting I was able to read/write all the data I needed.
Here’s my testing code, maybe it might be helpful for somebody. But sorry, the texts are in Czech. In the future I want to add there openHAB config files too.
https://github.com/sirjackal/brink-modbus
And here is a screenshot from openHAB BasicUI:
Best regards,
Jan
I have found this document at Brink, It describes all Modbus addresses for our Flair ventilation systems: https://www.brinkclimatesystems.nl/documenten/modbus-uwa2-b-uwa2-e-installation-regulations-614882.pdf
HTH.
Kind regards,
Xavier Miller
Hi Berndq, how did you generate this data? If I connect my Pi to the USB-RS485 device, how do I get this data for my Brink Renovent Excellent 300?
Also, tangential question: before connecting the USB-RS485 to the Brink, should I power off the Brink device?
not sure if I understand your question. you can use it as is, it’s the same for all Brink Renovent Excellent 300.
I figured it out using the manual of the Brink Connect and lots of trial and error with modpoll. details see above.
YES. You have to open the device in order to connect the brink connect.
Why do you cosinder not to open it?
To be honest, reading your questions makes me recommend you to ask someone with an electrical engineering background for assistance.
thank you, Berndq.
I was wondering: which command in the terminal resulted in this this output?
Please let me know if this is not clear yet.
this is not an output from any command but (part) of open hab configuration.
alright, thank you for the clarification
do you remember which command did you issue to use modpoll? I’m reading the documentation but I don’t see it can use /dev/ttyUSB0 . It seems to be connecting via http. Or am I wrong?
Thank you for guide and examples. I can confirm that it works with Brink flair 325. With several small corrections.
