Is the beta 2 still the latest or is there a newer one?
How can I add the Temperature Channel in broadlink?
I only have the command channel
Or do I need an A1?
If your device supports it, it should show when pressing the “show more” button. For me it works with a RM Pro.
I’ve got the RM PRO as well… not sure what is wrong.
From e-control when I control my aircon, I can see a temperature.
I’m assuming I’m getting that from the RM PRO
In this post, you can see the cannel you must have to show the RM Pro temperature in OH:
I’m pressing the wrong button… I was clicking the items under the channel. After clicking the show more I can see it now.
Thanks guys… again Cato Thank you and great work
Hi everyone, I’m new, I just installed OH2 on Qnap TS-212P and I’m trying to run the RM PRO. From how I understand I should install a dependency, but I do not know where.
Could you give me the steps in a very simple way? : P
Thank you
P.S. Sorry my english, i have to thank google translate
Have you read the posts here?, all the information you need is in there!.
What have you done so far?
Sorry, but I’m really inexperienced!
For the time being I installed OH2 and made the Chromecast audio binding.
From how I understand it is to install the plug-in done by Cato somewhere, but I did not understand where!
ok, i’ll try:
- Download the Broadlink binding from the Download link: https://goo.gl/CS4rE9
- stop OH and copy the .jar file in the OH Addons directory, start OH
- Now you should be able to see in the OH PaperUI that the binding is installed when you click: Configuration/Bindings
- Now you follow the great instructions off Cato: Broadlink binding for RMx, A1, SPx and MP. Any interest?
- If you have trouble finding the IV & KEY, search for “broadlink iv key” and it wil be on a github page, hit 3 or so, it is also called “initial vector” and “initial key”
Hope this helps,
Ray
Now it’s all clear to me! I did not know where to copy the file!
Thank you
How do you guys change the icon based on the state of the item.
All of my broadlink switches are all GREEN regardless of state
this item does not work even if I add
String HALLWAY_LAMP “HALLWAY_LAMP” { channel=“broadlink:rm2:b4-43-0d-aa-80-87:command” }
Hi
i have followed all the steps
the binding is well installed but the command in the UI do not work see below the current state
all the items are in status null.
i have well configured my mini RM and my RM but i am stucked here
below you can have a look on my config
i am trying to control a a IR AC and the broadlink wall plug TC2 with my RM Pro and from the mini, i am trying to control the kids rooms AC
i feel that i am so close… frustrating
C:\Users\smart_000\OpenHab2\conf\items*myitem.items*
String AC_LIVINGROOM “AC Living room” {channel=“broadlink:rm2:34-ea-34-c7-c9-15:command”}
String WALL_LIVINGROOM “Light Living Rooom” {channel=“broadlink:rm2:34-ea-34-c7-c9-15:command”}
String AC_ROOM “AC Kid Room” {channel=“broadlink:rm3:34-ea-34-c7-76-86:command”}
C:\Users\smart_000\OpenHab2\conf\sitemaps*new.sitemap*
Switch item=AC_LIVINGROOM label=“Power” mappings=[AC_LIVINGROOM_ON=“On”,AC_LIVINGROOM_OFF=“Off”]
Switch item=WALL_LIVINGROOM label=“Power” mappings=[WALL_POWER_ON=“On”, WALL_POWER_OFF=“Off”]
Switch item=AC_ROOM label=“Power” mappings=[AC_ROOM_ON=“On”,AC_ROOM_OFF=“Off”]
C:\Users\smart_000\OpenHab2\conf\transform*broadlink.map*
WALL_POWER_ON = 640184030a170a170b170d17170a170a0a170a17170a170a170a0a170a17170a0a17170a0a17170a0a17170a0a17170a170a0a170a17170a0a170a170a000149e00a170a0a170a17170a0a170a170a170a18170a170a0a170a17170a170a170a0a170a17170a0a17170a0a17170a0a17170a0a17170a170a0a170a17170a0a170b170b000149e00a170a0a170a17170a0a170a170a170a17170a170a0a170a17170a170a170a0a170a17170a0a17170a0a17170a0a17170a0a18170a170a0c180a17170a0a170a170a000149e00b170a0a170a17170a0a170a170a170a17170a170a0a170a17170a170a170a0a170a17170a0a17170a0a17170a0a17170a0a17170a170a0a170a17170a0a170a170a000149e00a170a0a170a17170a0a170a170a170a17180a170a0a170a17170a170a170a0a170a17170a0a17170a0a17170a0a17170a0a17170a170a0a170a17170a0a170a170a000149e00a170a0a170a17170a0a170a170a170a17170a170a0a170a17170a170a170a0a170a17170a0a17170a0a17170a0a17170a0a17170a170a0a170a17170a0a170a170a000149e00a170a0a170a17170a0a170a170a170a17170a170a0a170a17170a170a170a0a170a17170a0a17170a0a17170a0a17170a0a17170a170a0a170a17170a0a170a170a000149e10a170a0a170a17170a0a170a170a170a17170a170a0a170a17170a170a170a0a170a17170a0a17170b0a17170b0a17170a0a17170a170a0a170a17170a0a170a170a000149e00a170a0a170a17170a0a170a170a170a17170a170a0a170b17180a170a170a0a170a17170a0a17180a0a17170a0a17170a0a17170a170a0a170a17170a0a170a170a000149e00a170a0a180a18170a0a170a170a170a17170a170a0a170a17170a170a170a0a170a17170a0a17170a0a17170a0a17170a0a17170a170a0a170a17170a0a170a170a000170e10a170a0a170a17170a0a180a180a170a17170a170a0a170a17170a170a170a0a170a17170a0a17170a0a17170a0a17170a0a17170a170a0a170a17170a0a170a170a000149e00a170a0a170a17170a0a170a170a170a17170a170a0a170a17170a170a170a0a170a17170a0a17170a0a17170a0a17170a0a17170a170a0a170a17170a0a170a170a000149e00a170a0a170a17170a0a170a170a170a17170a170a0a170a17170a170a170a0a170a17170a0a17170a0a17170a0a17170a0a17170a170a0a170a17170a0a170a170a0005dc00000000
WALL_POWER_OFF = 640184030a170a17170a0a17170a0a170a170a170a17170b0a17170b170a170a170a170a170a0a170a17170a170a170a0a17170a0a170a170a17170a0a000149e00a170a170a0a17170a0b170b17170a0a17170a0a170a170a170a17180a0a17170a170a170a170a170a170a0a170a17170a170a170a0a17170a0a170a170a17170a0a000149e00a170a170a0a18170a0a170a17170a0a17170a0a170a170a170a17170a0a17170a170a170a170a170a170a0a170a17170a170a170a0a17170a0a170a170a17170a0a000149e00a170a170a0a17170a0a170a17170a0a17170a0a170a170a170a17170a0a17170a170a170a170a170a170a0a170a17170a170a170a0a17170a0a170a170a17170a0a000149e10a170a170a0a17170a0a170a17170a0a17170a0a170a170a170a17170a0a17170a170a170a170a170b170b0a170a17180b170a170a0a17170a0a170a170a17170a0a000149e00a170a170a0a17180a0d170a17170a0a17170a0a170a170a170a17170a0a17170a170a170a170a170a170a0a170a17170a170a170a0a17170a0a170a170a17170b0a000149e00a170a170a0a17170a0a170a17170a0a17170a0a170a170a170a17170a0a17170a170a170a170a170a170a0a170a17170a170a170a0a17170a0b170b170a17170a0a000149e00a170a170a0a17170a0a170a17170a0a17170a0a170a170a170a17170a0a17170a170a170a170a170a170a0a180a18170a170a170a0a17170a0a170a170a17170a0a000149e00b170b170a0a17170a0a170a17170a0a17170a0a170a170a170a17170a0a17170a170a170a170a170a170a0a170a17170a170a170a0a17170a0a170a170a17170a0a000149e00a180a170a0a17170a0a170b17170a0a17170a0a170a170a170a17170a0a17170a170a170a170a170a170a0a170a17170a170a170a0a17170a0a170a170a17170b0a000149e00a170a170a0a17170a0a170a17170a0a17170a0a170a170a170a17170a0a17170a170a170a170a170a170a0a170a17170a170a170a0b17180a0a170a170a17170a0a000149e00a170a170a0a17170a0a170a17170a0a17170a0a170a170a170a17170a0a17170a170a170a170a170a170a0a180a18170a170a170a0a17170a0a170a170a17170a0a000149e00b170b170a0a17170a0a170a17170a0a17170a0a170a170a170a17170a0a17170a170a170a170a170a170a0a170a17170a170a170a0a17170a0a170a170a17170a0a0005dc00000000
AC_LIVINGROOM_ON = 2600400000011281142f141014101410142f141014101410141014101410141014101411132f142f14101410142f14101410142f1410142f142f1411132f141014000d050000000000000000
AC_LIVINGROOM_OFF = 2600400000011281142f141014101410142f141014101410141014101410141014101411132f142f14101410142f14101410142f1410142f142f1411132f141014000d050000000000000000
C:\Users\smart_000\OpenHab2\conf\transform*broadlinkMini.map*
AC_ROOM_ON = 2600400000011281142f141014101410142f141014101410141014101410141014101411132f142f14101410142f14101410142f1410142f142f1411132f141014000d050000000000000000
AC_ROOM_OFF = 2600400000011281142f141014101410142f141014101410141014101410141014101411132f142f14101410142f14101410142f1410142f142f1411132f141014000d050000000000000000
Thanks in advance for your help
Hello nakh_Home,
I have not really been playing a lot with the RM2 and RM3 Mini, on the first face off it, what you do seems o.k.
First check some things off which I cannot see if its been configured:
- Did you add the IV & KEY for the RM’s and did you give in the name off the .map files?
- I,m not using PaperUI to control my devices I’m using BasicUI, and I configure everything accept the channels in config files, .items, home.sitemap, .rules files and so on, so I don’t now if it should work from PaperUI, maybe someone can confirm that?
- What does your log file say?
Ray
Ok, then, I removed from qnap and installed on raspberry pi zero w … all else! I copied the addon and found the device. Now I have the key problem … I can not figure out where to find them! Are they so embarrassed?
Ok, maybe I understand. I update you when done!
Google is your friend they say…
OK, the temperature works!
But … new problem!
I’ve created the various files in their folders:
Item file: (broadlink.items)
String CLIMATIZZATORE “Climatizzatore” {channel = “broadlink: rm2: 34: ea: 34: b5: 22: 07: command”}
Sitemap file: (broadlink.sitemap)
Switch item = CLIMATIZZATORE label = “Power” mappings = [ACCENDI_CLIMATIZZATORE = “On”, SPEGNI_CLIMATIZZATORE = “Off”]
Map file: (broadlink.map)
260092000001249513381413141413381437143714141314143714381314133814141314131414141314131414141314141314381338131414141314131414141338131414371414131414371414130002901314141413141314141413141413141413141414131413141414131413141414131414131414131414131414131414141314131414141314131414381338133813000d05000000000000
260092000001249513381314141413141437143714141314143714381314133814141314131414141314131414141314141314381314131414141314141314141338131414381314131414371414130002901413141413141414131413141414131413141414131413141414131414131414131414141314131414141314131414141314131414141314141314381338131414000d05000000000000
Unfortunately it does not work!
I also created an item within openhab, but it does not work I restarted the rspy too, but nothing!
