Browser fails to reach openHAB after install
I didnt have patient, so I gave it a shot without copying the files…
It is actully boot fine, and is installing openhabian right now :smiley:
EDIT. and now its done its 1 time setup… Going to test it.
EDIT again:
Seems like its up running. But port 8080 as well as 9001 is not responding, (gets a connection refused). I can SSH fine though.
Using username "openhabian".
openhabian@10.4.28.127's password:
Linux openhab 5.4.42-v8+ #1319 SMP PREEMPT Wed May 20 14:18:56 BST 2020 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Wi-Fi is currently blocked by rfkill.
Use raspi-config to set the country before use.
###############  openhab  #####################################################
##        Ip = 10.4.28.127
##   Release = Debian GNU/Linux 10 (buster)
##    Kernel = Linux 5.4.42-v8+
##  Platform = Raspberry Pi 4 Model B Rev 1.1
##    Uptime = 0 day(s). 0:14:46
## CPU Usage = 0% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
##  CPU Load = 1m: 0.20, 5m: 0.59, 15m: 0.64
##    Memory = Free: 1.57GB (43%), Used: 2.12GB (57%), Total: 3.70GB
##      Swap = Free: 0.09GB (100%), Used: 0.00GB (0%), Total: 0.09GB
##      Root = Free: 101.11GB (96%), Used: 4.11GB (4%), Total: 109.74GB
##   Updates = 72 apt updates available.
##  Sessions = 1 session(s)
## Processes = 127 running processes of 32768 maximum processes
              Welcome to            __  _____    ____  _
            ____  ____  ___  ____  / / / /   |  / __ )(_)___ _____
           / __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __  / / __ `/ __ \
          / /_/ / /_/ /  __/ / / / __  / ___ |/ /_/ / / /_/ / / / /
          \____/ .___/\___/_/ /_/_/ /_/_/  |_/_____/_/\__,_/_/ /_/
              /_/
                  openHAB 2.5.7-1 (Release Build)
Looking for a place to get started? Check out 'sudo openhabian-config' and the
documentation at https://www.openhab.org/docs/installation/openhabian.html
The openHAB dashboard can be reached at http://openhab:8080
To interact with openHAB on the command line, execute: 'openhab-cli --help'
[20:15:56] openhabian@openhab:~$
EDIT again.
I rebooted the system. And now I can access port 8080 and 9001. Things seems to be running.
Short update…
The Rpi4 runs way faster than ever with this 64bit opemhabian image… But using alot more memory due to 64bit ofcouse. (not sure if 64bit is really worth it).
Anyway, I installed a coupple of bindings, (system and ipcamera binding). And I installed FFMPEG to be used with the camera binding…
I had some issue with ipcamera binding (which I also had previously, so thats normal). I then stopped OH, cleaned cache and rebooted.
Everything came up running fine, except now the Frontail issue is now back. Frontail seems to be running, I just cant connect to it. After a few minutes of waiting, I suddenly can connect to it fine.
So, right now I have the exact same setup, and the exact same results I had previously,
Only change is, openhab seems to be running alot faster/smoother and using more memory due to the 64bit openhabian image.
