Manara
(Manara)
April 7, 2020, 4:26pm
1
Dear all,
I recently setup openhab2 on a Raspberry with the Bticino binding.
I’m using a few PLs with adresses above 9, how do you format these in the .items configuration file,
if this is possible at all ?
I have tried with {bticino=“if=bticino;who=1;what=0;where=110”} without success.
I did a search already but could not find a post related to this.
Thank you,
Manara
bastler
(stefan)
April 7, 2020, 5:11pm
2
hi,
what binding are you talking about? the openwebnet-binding for bticino? if yes you have to know that this binding has expired. you can check out here for a fix:
Ran into the connection cannot be established error, decompiling thru it is a date check in the openwebnet-lib library. Since the source code for the library is not part of GitHub its not a straight forward fix. Did a byte code edit and reassemble back and the new one seems to be working for me. The new expiry is now 2021-03-14 15:00:00. Pushed the jar here [Release Hack to fix binding expiry · jebu/openhab2-addons · GitHub ]. Hopefully it will suffice till @massi puts out an official release.
when you need to adress pl about 9 pay attention to add a leading zero for example for a=9, pl=12 it is “0912” - but this is to be defined in things-file, not in items
best, stefan
Manara
(Manara)
April 7, 2020, 7:55pm
3
Hi Stefan, thank you for your answer. I’m using the Bticino Binding 1.14.0.
And indeed, I have to use 4 digits when addressing PL above 9. Thanks !
