or app MyHome_up
Edit: View the pdf guide, how to use the app MyHome_up and how to create or find the password and ipaddress
or app MyHome_up
Michele, I retrieved the INSTALLER CODE, and I used it to enter in MyHome_Up as a superuser. I noticed that there is a password inside the System menu, and I changed it. However, I cannot connect through the OpenWebNet Tool using such password.
I really don’t understand where and how to retrieve the needed password ![]()
In MyHome app, in the last tab there is a section called “System”.
When you enter there there is a field called “Password open”
you should change that and use it in the binding
Many thanks, Enrico. It is exactly what I did. The server automatically restart it self after the password was changed. However, I still cannot connect to the system.
Hello Enrico,
you could post here a message with explanations and maybe with some images.
So a new user already knows what to do.
thanks a lot
I assume you have the webserver in Error in OH, right?
Check IP and password.
Post the OH log and image of things.
Ok, my fault. The password I inserted was too “strong”, and the system did not accept it. I have just tried again with a one more directly, and not I can connect. Many thanks to everyone!
Important that you succeeded ![]()
org.openhab.binding.openwebnet-2.5.0-M2
I am happy to report that CEN commands from Screen10 touch screen are detected by the binding.
That’s quite an improvement as it means I can get Openhab to run rules by simply touching the touching the screen 10 panel and no need for physical proxy actuators.
For me thats important when I want to run a rule/scenario with sub 1 sec timing control
eg
PIR override feature on many outdoor PIR operated lights
Fine blade control for blinds
Thanks Massimo ![]()
installs 2.5.0-M2-1
? Not sure what you mean… install M2-1 or the fix was in M2-1
Latest version of Massimo, here
Thanks, I have it but not tried yet. I need to check the effect of removing the switchable tag on Alexa… job for the weekend if its raining ![]()
I’m French sorry in advance for my English level
openhab version 2.4 and the latest version of openwebnet.
On my system I use a USB Zigbee key from Legrand. It is well recognized by openhab and controls well my equipment (lamp, roller shutter). My problem is that when I turn on my lamp via a physical switch there is no return on openhab.
Does anyone have a solution?
How can I view the log?
Discovered for testing before a real installation
So the key yes, but the elements
Status: OFFLINE - COMMUNICATION_ERROR Could not get channel state
but they responds well when you open them since openhab
Version OpenWebNet Binding (2.5.0.M2-1)
I find the log
Read Massimo’s README here
Read here
Always remember, when you place a log, use the icon.
If you don’t, you lose useful information
2019-04-10 11:25:24.564 [DEBUG] [ebnet.handler.OpenWebNetThingHandler] - ==OWN:ThingHandler== handleCommand() (command=OFF - channel=openwebnet:on_off_switch:e39f6283:switch_01)
2019-04-10 11:25:24.569 [DEBUG] [et.handler.OpenWebNetLightingHandler] - ==OWN:LightingHandler== handleSwitchCommand() (command=OFF - channel=openwebnet:on_off_switch:e39f6283:switch_01)
2019-04-10 11:25:24.573 [DEBUG] [et.handler.OpenWebNetLightingHandler] - ==OWN:LightingHandler== toWhere(ChannelUID) ownId=Z.0#672#34
2019-04-10 11:25:24.579 [INFO ] [org.openwebnet.OpenGatewayZigBee ] - SERIAL SENDING >>>>>>>>>>>>>>>>>>>>>>>> *1*0*0#672#3401#9##
