The colorpicker in the iOS app seems to have bugs.
When I select a color, countless requests are sent to the HUE Bridge. (Milliseconds)
The HUE Brigde also raises a mistake. Look in my logfile.
The whole thing only happens with the iOS app in for example BasicUI these errors do not occur. Setting a sendFrequency also brings no success.
I have tested it with 2 different or rather 3 different lamps. Innr RGB Bulb and Phillips RGB Bulb on openHAB 2.2.0 and with the Tradfri RGB lamp under openHAB 2.1.0 (and still under the old iOS app.)
Is that the same with you? If so, I would create an issue on Github.
12:25:51.695 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Stehlampe_Wohnzimmer_Schrank_Color' received command 69.971831,97.454702,99.000001
12:25:51.959 [INFO ] [smarthome.event.ItemStateChangedEvent] - Stehlampe_Wohnzimmer_Schrank_Color changed from 67.943662,97.454702,99.000001 to 69.971831,97.454702,99.000001
12:25:51.974 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Stehlampe_Wohnzimmer_Schrank_Color' received command 71.492958,97.454702,99.000001
12:25:51.988 [INFO ] [smarthome.event.ItemStateChangedEvent] - Stehlampe_Wohnzimmer_Schrank_Color changed from 69.971831,97.454702,99.000001 to 71.492958,97.454702,99.000001
12:25:52.003 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Stehlampe_Wohnzimmer_Schrank_Color' received command 73.521127,97.454702,99.000001
12:25:52.020 [INFO ] [smarthome.event.ItemStateChangedEvent] - Stehlampe_Wohnzimmer_Schrank_Color changed from 71.492958,97.454702,99.000001 to 73.521127,97.454702,99.000001
12:25:52.035 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Stehlampe_Wohnzimmer_Schrank_Color' received command 75.042254,97.454702,99.000001
12:25:52.050 [INFO ] [smarthome.event.ItemStateChangedEvent] - Stehlampe_Wohnzimmer_Schrank_Color changed from 73.521127,97.454702,99.000001 to 75.042254,97.454702,99.000001
12:25:52.066 [WARN ] [.binding.hue.handler.HueBridgeHandler] - Error while accessing light: Internal error, 404
org.eclipse.smarthome.binding.hue.internal.exceptions.ApiException: Internal error, 404
at org.eclipse.smarthome.binding.hue.internal.HueBridge.handleErrors(HueBridge.java:892) [238:org.eclipse.smarthome.binding.hue:0.10.0.b1]
at org.eclipse.smarthome.binding.hue.internal.HueBridge.setLightState(HueBridge.java:266) [238:org.eclipse.smarthome.binding.hue:0.10.0.b1]
at org.eclipse.smarthome.binding.hue.handler.HueBridgeHandler.updateLightState(HueBridgeHandler.java:201) [238:org.eclipse.smarthome.binding.hue:0.10.0.b1]
at org.eclipse.smarthome.binding.hue.handler.HueLightHandler.handleCommand(HueLightHandler.java:277) [238:org.eclipse.smarthome.binding.hue:0.10.0.b1]
at sun.reflect.GeneratedMethodAccessor108.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [109:org.eclipse.smarthome.core:0.10.0.b1]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [109:org.eclipse.smarthome.core:0.10.0.b1]
at com.sun.proxy.$Proxy169.handleCommand(Unknown Source) [238:org.eclipse.smarthome.binding.hue:0.10.0.b1]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:72) [116:org.eclipse.smarthome.core.thing:0.10.0.b1]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [116:org.eclipse.smarthome.core.thing:0.10.0.b1]
at sun.reflect.GeneratedMethodAccessor107.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [109:org.eclipse.smarthome.core:0.10.0.b1]
12:25:52.078 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Stehlampe_Wohnzimmer_Schrank_Color' received command 77.070423,97.454702,99.000001
12:25:52.289 [INFO ] [smarthome.event.ItemStateChangedEvent] - Stehlampe_Wohnzimmer_Schrank_Color changed from 75.042254,97.454702,99.000001 to 77.070423,97.454702,99.000001
12:25:52.309 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Stehlampe_Wohnzimmer_Schrank_Color' received command 79.605634,97.454702,99.000001
12:25:52.323 [INFO ] [smarthome.event.ItemStateChangedEvent] - Stehlampe_Wohnzimmer_Schrank_Color changed from 77.070423,97.454702,99.000001 to 79.605634,97.454702,99.000001
12:25:52.337 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Stehlampe_Wohnzimmer_Schrank_Color' received command 81.633803,97.454702,99.000001
12:25:52.353 [INFO ] [smarthome.event.ItemStateChangedEvent] - Stehlampe_Wohnzimmer_Schrank_Color changed from 79.605634,97.454702,99.000001 to 81.633803,97.454702,99.000001
12:25:52.373 [WARN ] [.binding.hue.handler.HueBridgeHandler] - Error while accessing light: Internal error, 404
