BUG - OH3.2 FINAL Map Transformation with Large Items File (Rest API on Items)
The thing is, the transformation is already done and dusted before the error-insert in the REST JSON e.g.
{"link":"http://openhabian:8080/rest/items/Onkyo_LivingRoom_Input","state":"17","transformedState":"Nvidia","stateDescription":{"pattern":"MAP(onkyo_source.map):%s","readOnly":false,"options":[{"value":"16","label":"CABLE"},{"value":"1","label":"ROKU"},{"value":"2","label":"GAME"},{"value":"17","label":"NVIDIA"},{"value":"5","label":"MAC Old"},{"value":"3","label":"AUX"},{"value":"37","label":"AM"},{"value":"36","label":"FM"},{"value":"35","label":"PHONO"},{"value":"18","label":"TV"},{"value":"34","label":"NOT USED"},{"value":"43","label":"NET"},{"value":"46","label":"BLUETOOTH"},{"value":"128","label":"Source"}]},"commandDescription":{"commandOptions":[{"command":"16","label":"CABLE"},{"command":"1","label":"ROKU"},{"command":"2","label":"GAME"},{"command":"17","label":"NVIDIA"},{"command":"5","label":"MAC Old"},{"command":"3","label":"AUX"},{"command":"37","label":"AM"},{"command":"36","label":"FM"},{"command":"35","label":"PHONO"},{"command":"18","label":"TV"},{"command":"34","label":"NOT"{\"error\":{\"message\":\"begin 0, end -1, length 12\",\"http-code\":500,\"exception\":{\"class\":\"java.lang.StringIndexOutOfBoundsException\",\"message\":\"begin 0, end -1, length 12\",\"localized-message\":\"begin 0, end -1, length 12\"}}}"
Note this time "transformedState":"Nvidia" is all good, and the extraneous rubbish turns up partway through the list of command options
where I guess NOT should be NOT USED and as a command option has nothing to do with maps or transformations.
I don’t believe the error comes from the transformation, because that has completed and returned the expected answer. It’s something else about starting another asynchronous thread or taking more time when a transformation is invoked.
Is this entirely predictable? i.e. if you run the query twice with no changes, is it always the exact same point of failure? that would be more surprising than not, to me.
When I refresh the http rest call - it’s at the same place until I comment out that item. So that is consistent.
Best, Jay
Really interesting - suggests not timing, which does surprise me.
Some experiments to try, not sure what they will prove. I’m conscious that any edit to your mega xxx.items file refreshes all Items.
With a “culprit” Item identified from a failed list call, try a REST call of that single Item. Should rule out the internal JSONDB being corrupted, or basic transformation issues.
Then repeat the list call to see if the exact error persists. Might have flushed some cache somewhere.
Without editing your mega xxx.items file, add a brand new dummy Item in a separate .items file. See what REST list does then. This will ‘disturb’ internal JSONDB by addition.
Assuming still wrong - without editing mega file, make a duplicate entry for the offending Item in the extra .items file and save. This should I think replace only the Item in internal image. Test list.
If still same - edit the duplicate with a label change or suchlike, test again. (to prove this process replaces)
If still same - edit the duplicate to remove the MAP function, test again (to see if its really about the MAP work on this individual Item).
If still same - edit the mega file to remove original. This should refresh everybody except our culprit I think.
While the duplicate exists, we’re bending the rules of course and results may be unpredictable - but one working, REST-able Item should still exist internally.
If shuffling a ‘culprit’ Item about like that changes the error - it might be interesting to then shuffle a unproblematic bystander Item about, perhaps from both before and after in file position of the current culprit. Might show if the issue links to Item or list position.
Or something weird like the 255th MAP transform in this list …
Here’s the findings:
MAP binding NOT installed:
Created dummy.items file with just 1 item in it.
Switch	Dummy			"Dummy [MAP(On_Off.map):%s]"
http://openhabian:8080/rest/items  <-- worked on all items from both files
{"link":"http://openhabian:8080/rest/items/Dummy","state":"NULL","stateDescription":{"pattern":"MAP(On_Off.map):%s","readOnly":false,"options":[]},"editable":false,"type":"Switch","name":"Dummy","label":"Dummy","tags":[],"groupNames":[]}
http://openhabian:8080/rest/items/Dummy   <-- worked on the 1 item in dummy.items
http://openhabian:8080/rest/items/Dummy/state  <-- worked on the 1 item in dummy.items
NULL
MAP binding installed:
http://openhabian:8080/rest/items  <-- failed on ALL items
{"link":"http://openhabian:8080/rest/items/Echo_GuestRoom_ArmStateSmoke","state":"OPEN","transformedState":"On""{\"error\":{\"message\":\"begin 0, end -1, length 12\",\"http-code\":500,\"exception\":{\"class\":\"java.lang.StringIndexOutOfBoundsException\",\"message\":\"begin 0, end -1, length 12\",\"localized-message\":\"begin 0, end -1, length 12\"}}}"
http://openhabian:8080/rest/items/Dummy <-- worked on dummy.item file
{"link":"http://openhabian:8080/rest/items/Dummy","state":"NULL","transformedState":"Off","stateDescription":{"pattern":"MAP(On_Off.map):%s","readOnly":false,"options":[]},"editable":false,"type":"Switch","name":"Dummy","label":"Dummy","tags":[],"groupNames":[]}
http://openhabian:8080/rest/items/Dummy/state <-- worked on dummy.item file
NULL
Trying one of the failing items above in the 2400 item default.items file.
http://openhabian:8080/rest/items/Echo_GuestRoom_ArmStateSmoke  <-- worked
{"link":"http://openhabian:8080/rest/items/Echo_GuestRoom_ArmStateSmoke","state":"OPEN","transformedState":"On","stateDescription":{"pattern":"MAP(alexaguard.map):%s","readOnly":true,"options":[]},"editable":false,"type":"Contact","name":"Echo_GuestRoom_ArmStateSmoke","label":"Smoke Arm State","tags":[],"groupNames":["gArmStateSmoke"]}
http://openhabian:8080/rest/items/Echo_GuestRoom_ArmStateSmoke/state <-- worked
OPEN
I’m guessing when pulling a single item via REST API isn’t enough load on the possible (timing out) vs. pulling back 2400 items at once hence it worked with 1 item.
Next steps?
Best, Jay
Hi @Kai,
I’m wondering what the next steps are to getting the REST Item API / MAP Transformation looked at for a large .items file?
Best, Jay
@Kai,
Looks like we have similar issues on this thread with timing out.
Best, Jay
@Kai,
OH 3.2m5 still has the same issue with a 2400+ item file using MAP transformation still. I hope someone can look at this before RC1 is started.
2021-12-08 15:17:33.500 [ERROR] [org.apache.cxf.jaxrs.utils.JAXRSUtils             ] - Problem with writing the data, class org.openhab.core.io.rest.Stream2JSONInputStream, ContentType: application/json
2021-12-08 15:17:33.514 [ERROR] [.io.rest.core.internal.JSONResponseExceptionMapper] - Unexpected exception occurred while processing REST request.
java.lang.StringIndexOutOfBoundsException: begin 0, end -1, length 12
	at java.lang.String.checkBoundsBeginEnd(String.java:3319) ~[?:?]
	at java.lang.String.substring(String.java:1874) ~[?:?]
	at org.openhab.core.transform.AbstractFileTransformationService.getLocalizedProposedFilename(AbstractFileTransformationService.java:274) ~[?:?]
	at org.openhab.core.transform.AbstractFileTransformationService.transform(AbstractFileTransformationService.java:135) ~[?:?]
	at org.openhab.core.transform.TransformationHelper.transform(TransformationHelper.java:125) ~[?:?]
	at org.openhab.core.transform.TransformationHelper.transform(TransformationHelper.java:100) ~[?:?]
	at org.openhab.core.io.rest.core.item.EnrichedItemDTOMapper.considerTransformation(EnrichedItemDTOMapper.java:131) ~[?:?]
	at org.openhab.core.io.rest.core.item.EnrichedItemDTOMapper.map(EnrichedItemDTOMapper.java:68) ~[?:?]
	at org.openhab.core.io.rest.core.item.EnrichedItemDTOMapper.map(EnrichedItemDTOMapper.java:62) ~[?:?]
	at org.openhab.core.io.rest.core.internal.item.ItemResource.lambda$2(ItemResource.java:215) ~[?:?]
	at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195) ~[?:?]
	at java.util.HashMap$KeySpliterator.tryAdvance(HashMap.java:1642) ~[?:?]
	at java.util.stream.StreamSpliterators$WrappingSpliterator.lambda$initPartialTraversalState$0(StreamSpliterators.java:294) ~[?:?]
	at java.util.stream.StreamSpliterators$AbstractWrappingSpliterator.fillBuffer(StreamSpliterators.java:206) ~[?:?]
	at java.util.stream.StreamSpliterators$AbstractWrappingSpliterator.doAdvance(StreamSpliterators.java:169) ~[?:?]
	at java.util.stream.StreamSpliterators$WrappingSpliterator.tryAdvance(StreamSpliterators.java:300) ~[?:?]
	at java.util.Spliterators$1Adapter.hasNext(Spliterators.java:681) ~[?:?]
	at org.openhab.core.io.rest.Stream2JSONInputStream.fillBuffer(Stream2JSONInputStream.java:94) ~[?:?]
	at org.openhab.core.io.rest.Stream2JSONInputStream.read(Stream2JSONInputStream.java:70) ~[?:?]
	at java.io.InputStream.read(InputStream.java:280) ~[?:?]
	at java.io.InputStream.transferTo(InputStream.java:704) ~[?:?]
	at org.openhab.core.io.rest.core.internal.GsonMessageBodyWriter.writeTo(GsonMessageBodyWriter.java:84) ~[?:?]
	at org.openhab.core.io.rest.core.internal.MediaTypeExtension.writeTo(MediaTypeExtension.java:84) ~[?:?]
	at org.apache.cxf.jaxrs.utils.JAXRSUtils.writeMessageBody(JAXRSUtils.java:1543) ~[bundleFile:3.4.5]
	at org.apache.cxf.jaxrs.interceptor.JAXRSOutInterceptor.serializeMessage(JAXRSOutInterceptor.java:249) ~[bundleFile:3.4.5]
	at org.apache.cxf.jaxrs.interceptor.JAXRSOutInterceptor.processResponse(JAXRSOutInterceptor.java:122) ~[bundleFile:3.4.5]
	at org.apache.cxf.jaxrs.interceptor.JAXRSOutInterceptor.handleMessage(JAXRSOutInterceptor.java:84) ~[bundleFile:3.4.5]
	at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) ~[bundleFile:3.4.5]
	at org.apache.cxf.interceptor.OutgoingChainInterceptor.handleMessage(OutgoingChainInterceptor.java:90) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:298) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doGet(AbstractHTTPServlet.java:222) ~[bundleFile:3.4.5]
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[bundleFile:3.1.0]
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:273) ~[bundleFile:3.4.5]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550) ~[bundleFile:9.4.43.v20210629]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1434) ~[bundleFile:9.4.43.v20210629]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1349) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.43.v20210629]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:82) ~[bundleFile:?]
	at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:386) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.43.v20210629]
2021-12-08 15:17:34.845 [ERROR] [org.apache.cxf.jaxrs.utils.JAXRSUtils             ] - Problem with writing the data, class org.openhab.core.io.rest.Stream2JSONInputStream, ContentType: application/json
2021-12-08 15:17:34.846 [ERROR] [.io.rest.core.internal.JSONResponseExceptionMapper] - Unexpected exception occurred while processing REST request.
Best, Jay
@Kai,
I removed 240 MAP transitions on my item file leaving 400 MAP transitions still in there. This reduction did NOT stop the errors being caused above still.
Best, Jay
@Kai ,
Upgraded from OH from 3.2m5 to 3.2 Final and the bug still exists with large number of items using MAP transformation.
I even paired down my MAP items, again, down to 125 from 240 from the last post. A single REST call to an item with MAP involved works but it does NOT work when retrieving all the items at once. Here’s the error at hand, same as before.
2022-01-02 14:29:44.184 [ERROR] [.io.rest.core.internal.JSONResponseExceptionMapper] - Unexpected exception occurred while processing REST request.
2022-01-02 14:29:53.584 [ERROR] [org.apache.cxf.jaxrs.utils.JAXRSUtils             ] - Problem with writing the data, class org.openhab.core.io.rest.Stream2JSONInputStream, ContentType: application/json
2022-01-02 14:29:53.586 [ERROR] [.io.rest.core.internal.JSONResponseExceptionMapper] - Unexpected exception occurred while processing REST request.
On a hunch, I followed what this post talks about with MAP files being renamed and shortened. I renamed all my .MAP files to 8 characters or less w/o any dashes or underscores and changed the references to them in the ITEMS and RULES and IT WORKED!
Best, Jay
Interesting. That allows for underlying filesystem issues. Also for some possible intermediate caching misbehaviour.
Hey @jwiseman,
Glad to see that you found a solution.
I think the exception should be fixed nonetheless. Is there already an issue for it on Github (GitHub · Where software is built)? If not, could you please enter one?
Still looks like there are other issues at hand with a large item file - just got this dump which has similar ( org.apache.cxf.jaxrs.utils.JAXRSUtils ) errors in the above threads from my many postings. I attempted to get your attention to this issue back on Nov 21st.
2022-01-04 20:28:27.498 [ERROR] [org.apache.cxf.jaxrs.utils.JAXRSUtils             ] - Problem with writing the data, class org.openhab.core.io.rest.Stream2JSONInputStream, ContentType: application/json
2022-01-04 20:28:27.499 [ERROR] [.io.rest.core.internal.JSONResponseExceptionMapper] - Unexpected exception occurred while processing REST request.
java.io.IOException: java.util.concurrent.TimeoutException: Idle timeout expired: 30000/30000 ms
	at org.eclipse.jetty.util.SharedBlockingCallback$Blocker.block(SharedBlockingCallback.java:257) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpOutput.channelWrite(HttpOutput.java:270) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:869) ~[bundleFile:9.4.43.v20210629]
	at org.apache.cxf.io.AbstractWrappedOutputStream.write(AbstractWrappedOutputStream.java:51) ~[bundleFile:3.4.5]
	at java.io.InputStream.transferTo(InputStream.java:705) ~[?:?]
Caused by: java.util.concurrent.TimeoutException: Idle timeout expired: 30000/30000 ms
	at org.eclipse.jetty.io.IdleTimeout.checkIdleTimeout(IdleTimeout.java:171) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.io.IdleTimeout.idleCheck(IdleTimeout.java:113) ~[bundleFile:9.4.43.v20210629]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[?:?]
	... 1 more
Best, Jay
