I’m nearing completion of my OH2 migration and I started on the smoke detectors today. I’ve got my rules set up and shortly after I added the Items & Links, my whole house went nuts (my rules turn on all lights and set a repeating message on the Sonos system).
There are two different alarms for this device, the APPLIANCE alarm - type 12 and the HOME_HEALTH alarm - type 13. The APPLIANCE alarm is the actual alarm, the HOME_HEALTH alarm is a heartbeat that happens every hour. Unfortunately the current binding seems to support only OnOffType so both alarms set the Switch thing to ON. I know the 1.8 binding could set the Item to a Number which was what my old rule used to determine heartbeat from alarm but that isn’t an option with OH2, the link seems to only allow a Switch.
I don’t see any way to distinguish them in the rule so I’m not sure how to continue. @chris is this a known issue? If I need to file a bug, how would I do such a thing? It seems that the HOME_HEALTH alarm should be ignored.
relavant data:
Actual Alarm going off:
15:01:02.279 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 29 04 71 05 0C FF 5B
15:01:02.283 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15:01:02.285 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 04 00 29 04 71 05 0C FF 5B
15:01:02.287 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0A 00 04 00 29 04 71 05 0C FF 5B
15:01:02.289 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 29 04 71 05 0C FF
15:01:02.290 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 41: Application Command Request (ALIVE:DONE)
15:01:02.291 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 41: Starting initialisation from DONE
5:01:02.293 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 41: Incoming command class ALARM
15:01:02.294 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 41: Received ALARM command V1
15:01:02.295 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 41: Process NOTIFICATION_REPORT V1
15:01:02.296 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 41: ALARM report - 12 = 255
15:01:02.299 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 41: Alarm Type = APPLIANCE (12)
15:01:02.301 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
15:01:02.304 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 41: Got an event from Z-Wave network: ZWaveAlarmValueEvent
15:01:02.306 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 41: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
15:01:02.309 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing ALARM
15:01:02.312 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 41: Updating channel state zwave:device:db95ddc3:node41:alarm_general to ON [OnOffType]
Heartbeat message (node48 is also a ZCOMBO, its just the first one to trigger since I started writing this):
15:40:08.252 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 30 04 71 05 0D FF 43
15:40:08.258 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15:40:08.259 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 04 00 30 04 71 05 0D FF 43
15:40:08.261 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0A 00 04 00 30 04 71 05 0D FF 43
15:40:08.263 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 30 04 71 05 0D FF
15:40:08.264 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 48: Application Command Request (DEAD:DONE)
15:40:08.264 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 48: Node is ALIVE. Init stage is DONE.
15:40:08.265 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveNodeStatusEvent
15:40:08.266 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 48: Got an event from Z-Wave network: ZWaveNodeStatusEvent
15:40:08.267 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 48: Setting ONLINE
15:40:08.272 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 48: Node Status event - Node is ALIVE
15:40:08.273 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:device:db95ddc3:node48' changed from OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller to ONLINE
15:40:08.279 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 48: Starting initialisation from DONE
15:40:08.281 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 48: Incoming command class ALARM
15:40:08.281 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 48: Received ALARM command V1
15:40:08.282 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 48: Process NOTIFICATION_REPORT V1
15:40:08.285 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 48: ALARM report - 13 = 255
15:40:08.286 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 48: Alarm Type = HOME_HEALTH (13)
15:40:08.286 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
15:40:08.287 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 48: Got an event from Z-Wave network: ZWaveAlarmValueEvent
15:40:08.287 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 48: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
15:40:08.289 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing ALARM
15:40:08.289 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 48: Updating channel state zwave:device:db95ddc3:node48:alarm_general to ON [OnOffType]
The device XML:
node41.xml (5.0 KB)
