After updating openHUB2 from Build # 1603 to Build # 1656, MQTT does not work
2019-08-10 10:34:37.706 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.mqtt.handler.BrokerHandler@518ef1aa': org.eclipse.paho.client.mqttv3.MqttConnectOptions.setHttpsHostnameVerificationEnabled(Z)V
java.lang.NoSuchMethodError: org.eclipse.paho.client.mqttv3.MqttConnectOptions.setHttpsHostnameVerificationEnabled(Z)V
at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection.createMqttOptions(MqttBrokerConnection.java:635) ~[?:?]
at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection.start(MqttBrokerConnection.java:720) ~[?:?]
at org.openhab.binding.mqtt.handler.AbstractBrokerHandler.initialize(AbstractBrokerHandler.java:108) ~[?:?]
at org.openhab.binding.mqtt.handler.BrokerHandler.initialize(BrokerHandler.java:232) ~[?:?]
at sun.reflect.GeneratedMethodAccessor64.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [133:org.openhab.core:2.5.0.201908052317]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [133:org.openhab.core:2.5.0.201908052317]
2019-08-10 10:34:37.753 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'mqtt:broker:v_mqtt': org.eclipse.paho.client.mqttv3.MqttConnectOptions.setHttpsHostnameVerificationEnabled(Z)V
openhab> bundle:list -s | grep -i paho
202 x Active x 80 x 1.2.0 x org.eclipse.paho.client.mqttv3
221 x Active x 80 x 1.2.1 x org.eclipse.paho.client.mqttv3
Thank you very much, I understood the problem, deleted the extra library, it was in add-ons, for another binding, I will understand further!
When restarting openHAB2, I see the following in the logs (I cleaned the cache and pace, overloaded it several times), is this the norm ?:
2019-08-15 10:19:48.463 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:kitchen_stove_things tried updating channel rssi although the handler was already disposed.
2019-08-15 10:19:48.464 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:kitchen_stove_things tried updating channel uptime although the handler was already disposed.
2019-08-15 10:19:48.464 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:kitchen_stove_things tried updating channel state although the handler was already disposed.
2019-08-15 10:19:48.507 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:kitchen_stove_things tried updating channel current although the handler was already disposed.
2019-08-15 10:19:48.511 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:kitchen_stove_things tried updating channel total although the handler was already disposed.
2019-08-15 10:19:48.512 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:kitchen_stove_things tried updating channel voltage although the handler was already disposed.
2019-08-15 10:19:48.512 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:kitchen_stove_things tried updating channel app_power although the handler was already disposed.
2019-08-15 10:19:48.513 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:kitchen_stove_things tried updating channel yesterday although the handler was already disposed.
2019-08-15 10:19:48.513 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:kitchen_stove_things tried updating channel react_pwr although the handler was already disposed.
2019-08-15 10:19:48.514 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:kitchen_stove_things tried updating channel powerload although the handler was already disposed.
2019-08-15 10:19:48.519 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:kitchen_stove_things tried updating channel today although the handler was already disposed.
2019-08-15 10:19:50.497 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:pump_water_things tried updating channel state although the handler was already disposed.
2019-08-15 10:19:50.498 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:pump_water_things tried updating channel rssi although the handler was already disposed.
2019-08-15 10:19:50.498 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:pump_water_things tried updating channel uptime although the handler was already disposed.
2019-08-15 10:19:50.503 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:pump_water_things tried updating channel vcc although the handler was already disposed.
2019-08-15 10:19:50.544 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:pump_water_things tried updating channel today although the handler was already disposed.
2019-08-15 10:19:50.545 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:pump_water_things tried updating channel voltage although the handler was already disposed.
2019-08-15 10:19:50.545 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:pump_water_things tried updating channel yesterday although the handler was already disposed.
2019-08-15 10:19:50.546 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:pump_water_things tried updating channel react_pwr although the handler was already disposed.
2019-08-15 10:19:50.546 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:pump_water_things tried updating channel powerload although the handler was already disposed.
2019-08-15 10:19:50.547 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:pump_water_things tried updating channel app_power although the handler was already disposed.
2019-08-15 10:19:50.548 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:pump_water_things tried updating channel current although the handler was already disposed.
2019-08-15 10:19:50.548 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:pump_water_things tried updating channel total although the handler was already disposed.
There is something strange going on. Can you please move all things files to another directory and see if this still happens after a restart? I have never seen that. But I don’t use textual configuration.
2019-08-17 19:53:59.620 [WARN ] [t.generic.ChannelStateTransformation] - Transformation service JSONPATH for pattern $.POWER not found!
2019-08-17 19:53:59.620 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command ‘{“Time”:“2019-08-17T12:53:58”,“Uptime”:“3T05:14:10”,“Vcc”:3.523,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“POWER”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“svm”,“BSSId”:“52:FF:20:40:1F:90”,“Channel”:11,“RSSI”:36,“LinkCount”:1,“Downtime”:“0T00:00:10”}}’ not supported by type ‘OnOffValue’: No enum constant org.eclipse.smarthome.core.library.types.OnOffType.{“Time”:“2019-08-17T12:53:58”,“Uptime”:“3T05:14:10”,“Vcc”:3.523,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“POWER”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“svm”,“BSSId”:“52:FF:20:40:1F:90”,“Channel”:11,“RSSI”:36,“LinkCount”:1,“Downtime”:“0T00:00:10”}}
2019-08-17 19:53:59.621 [WARN ] [t.generic.ChannelStateTransformation] - Transformation service JSONPATH for pattern $.Wifi.RSSI not found!
2019-08-17 19:53:59.622 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Incoming payload ‘{“Time”:“2019-08-17T12:53:58”,“Uptime”:“3T05:14:10”,“Vcc”:3.523,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“POWER”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“svm”,“BSSId”:“52:FF:20:40:1F:90”,“Channel”:11,“RSSI”:36,“LinkCount”:1,“Downtime”:“0T00:00:10”}}’ not supported by type ‘NumberValue’
With the transformation, everything is fine, warnings as in the first post.
PS cleared the cache, rebooted, now when you stop openHAB2, in the warning log about the transformation constantly:
2019-08-17 20:53:34.794 [WARN ] [t.generic.ChannelStateTransformation] - Transformation service JSONPATH for pattern $.Wifi.RSSI not found!
2019-08-17 20:53:34.795 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Incoming payload '{"Time":"2019-08-17T20:53:33","Uptime":"4T01:37:16","Vcc":2.960,"Wifi":{"AP":1,"SSId":"svm","RSSI":100,"APMac":"52:FF:20:40:1F:90"}}' not supported by type 'NumberValue'
2019-08-17 20:53:34.796 [WARN ] [t.generic.ChannelStateTransformation] - Transformation service JSONPATH for pattern $.Uptime not found!
2019-08-17 20:53:34.796 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GenericMQTTThingHandler of thing mqtt:topic:v_mqtt:thank_things tried updating channel uptime although the handler was already disposed.
2019-08-17 20:53:34.838 [WARN ] [t.generic.ChannelStateTransformation] - Transformation service JSONPATH for pattern $.Switch3 not found!
2019-08-17 20:53:34.839 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command '{"Time":"2019-08-17T20:53:33","Switch1":"ON","Switch2":"ON","Switch3":"ON","Switch4":"OFF","DS18B20":{"Temperature":16.0},"TempUnit":"C"}' not supported by type 'OnOffValue': No enum constant org.eclipse.smarthome.core.library.types.OnOffType.{"Time":"2019-08-17T20:53:33","Switch1":"ON","Switch2":"ON","Switch3":"ON","Switch4":"OFF","DS18B20":{"Temperature":16.0},"TempUnit":"C"}
2019-08-17 20:53:34.839 [WARN ] [t.generic.ChannelStateTransformation] - Transformation service JSONPATH for pattern $.Switch2 not found!
Transformation warnings are not always available, as in the stop example above.
The warnings shown above are not displayed for all things and their quantity and the things themselves change from time to time.
At assembly 1603 this was not at all.
Yes, I would expect it depends what incoming MQTT messages arrive for processing after the shutdown has begun.
Perhaps the order of shutting down things has changed, perhaps the messages were suppressed before.
