Is there a way to set a variable too without an action: variable
Idea is to evaluate a certain condition only once and use the result multiple times, e.g. for visibility of some of the widget components…
Hey,
I am trying to organize my widgets in a way that they look properly and there are no gaps between rows.
What I have today:
Any idea how to make that disappear? I tried to add two widgets to the same oh-grid-col but then it is not displaying anything.
The code looks like this:
label: Living Room
sidebar: true
order: "1"
blocks:
- component: oh-block
config: {}
slots:
default:
- component: oh-grid-row
config: {}
slots:
default:
- component: oh-grid-col
width: "100"
small: "50"
medium: "33"
slots:
default:
- component: widget:label-cell
header: Dining Room
item: TemperatureDiningRoom_Temperature
secondaryitem: TemperatureDiningRoom_Humidity
width: "100"
small: "50"
medium: "33"
slots:
default:
- component: widget:weatherCard
widget_action: popup
widget_actionModal: widget:weatherPopup
bigCard: false
sunIndicator: true
dateScheme: YYYY-DD-MM
dateFormat: true
itemPrefix2: LocalWeatherAndForecast_
itemPrefix: OneCallAPI_
widget_actionModalConfig:
forecastDays: 4
locationTitle: Weather
width: "100"
medium: "33"
slots:
default:
header: Living Room
item: OutletandTemperatureLivingRoom_Temperature
secondaryitem: OutletandTemperatureLivingRoom_Humidity
config: {}
slots:
default:
width: "100"
small: "50"
medium: "33"
slots:
default:
- component: widget:Shelly_RGBW
title: Dining Room RGBW
power: RGBWLedStripDiningRoom_Power
color: RGBWLedStripDiningRoom_Color
gain: RGBWLedStripDiningRoom_Gain
white: RGBWLedStripDiningRoom_White
colormode: RGBWLedStripDiningRoom_ColorMode
width: "100"
small: "50"
medium: "33"
slots:
default: []
width: "100"
medium: "33"
slots:
default: []
masonry: []
My other question is whether it is possible to have direct links to the UI without the top bar and the left menu bar. I will have some room controller screens based on rPi and I am looking for some kind of kiosk mode.
Thanks!
Hi, your weather widget has a different hight vs. the room temperature widget, so it is a matter of fact that you have gaps. You can consider to use different blocks for it, e.g. a top block with the weather widget and another block for the temperature widgets. then you wont have gaps like this. I have worked around with this and positioned different widget with different sizes in multiple blocks. If you want all of your widgets in the same block, you can alternatively use custom widgets that all have the same hight.
if you then make sure they have the same max width, they flow nicely with the size of the page.
trying to answer your second question. You can create a layout page and link directly to it or open it in a browser. I believe you cannot get completely rid of the navigation bar, but minimize it. Here is a good discussion to follow:
Thanks! I’ll come up with something then, either reorg or change the heights.
could you please post the code again I unfortunately can’t set the Hex Opacity Value Thank you!!!
i assume you talk about the buttons.
"white" : "rgba(228,228,228,0.9)
ON is white and OFF is rgba value.
Could you please share that weather widget, please?
Sure. It is based on the weather widget items definition from @RGroll, so using the prefix and items definition:
Here is my code. Please note that i have a link to wetteronline at the bottom of the code. Please adapt or link to whatever you like.
uid: weather_widget_v1
tags:
- homekit look
- black
- in use
props:
parameters:
- description: Location?
label: Location
required: false
type: TEXT
- context: item
description: Outdoor Temperature Item
label: Item
required: false
type: TEXT
- context: item
description: Daily Minimum Temperature
label: Item
required: false
type: TEXT
- context: item
label: Item
required: false
type: TEXT
- description: <b>Optional prefix</b> for item names.
label: Item prefix
required: false
type: TEXT
parameterGroups: []
timestamp: Feb 13, 2021, 12:44:48 PM
component: f7-card
style:
noShadow: false
class:
- padding
box-shadow: var(--f7-card-expandable-box-shadow)
background: linear-gradient(to top, rgba(0,0,0,1) 35%, rgba(80,80,80,1) 100%)
height: 8.5em
min-width: 9.5em
max-width: 400px
slots:
content:
- component: f7-block
style:
margin: -9px
padding: 0px
display: flex
flex-direction: column
align-items: start
- component: f7-row
class:
- justify-content-left
slots:
default:
- component: Label
text: =props.propLoc
class: -margin-top
style:
color: rgb(255,255,255)
font-size: 20px
overflow: hidden
text-overflow: ellipsis
text-transform: uppercase
white-space: nowrap
margin-bottom: 0px
- component: f7-row
slots:
default:
- component: f7-icon
f7: "=(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '01d') ? 'sun_max_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '01n') ? 'moon_stars_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '02d') ? 'cloud_sun_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '02n') ? 'cloud_moon_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '03d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '03n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '04d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '04n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '09d') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '09n') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '10d') ? 'cloud_sun_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '10n') ? 'cloud_moon_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '11d') ? 'cloud_sun_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '11n') ? 'cloud_moon_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '13d') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '13n') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '50d') ? 'cloud_fog_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '50n') ? 'cloud_fog_fill' : ''"
color: white
- component: Label
text: =(Number.parseFloat(items[props.itemTempOut].state.split(" ")[0]) * 100 / 100).toFixed(0) + '°'
class: -margin-top
style:
font-size: 40px
margin-left: -2px
margin-top: -9px
white-space: nowrap
overflow: hidden
font-weight: 300
- component: f7-row
class:
slots:
default:
- component: Label
text: "=(!props.itemPrefix) ? items.Current_Condition.state : items[props.itemPrefix + 'Current_Condition'].state"
style:
font-size: 10px
margin-left: 1px
margin-bottom: 0px
margin-top: 0px
white-space: nowrap
overflow: hidden
font-weight: 400
- component: f7-row
class:
slots:
default:
- component: Label
text: ="Hi:" +" " + (Number.parseFloat(items[props.itemTempMax].state.split(" ")[0]) * 100 / 100).toFixed(0) + '°'
style:
font-size: 14px
margin-left: 0px
margin-top: 0px
white-space: nowrap
overflow: hidden
font-weight: 500
- component: Label
text: ="| Lo:" +" " + (Number.parseFloat(items[props.itemTempMin].state.split(" ")[0]) * 100 / 100).toFixed(0) + '°'
style:
font-size: 14px
margin-left: 0px
margin-top: 0px
white-space: nowrap
overflow: hidden
font-weight: 400
- component: oh-link
action: url
actionUrl: http://m.wetteronline.de/yourtown
open-in: .popOver
style:
position: absolute
width: 100%
height: 100%
top: 0
left: 0
I really love your IOS Style Widgets do you have a page oder something where i can finde all your “codes” or don’t you want to publish it, which would be perfectly fine
Thanks for the help! Made some modifications to show more and now it fits
no problem to share some of them:
Switch:
uid: widget_f7-card_test_v3
tags:
- homekit-look
- in use
props:
parameters:
- description: A text prop
label: Prop 1
required: false
type: TEXT
- context: item
description: An item to control
label: Item
required: false
type: TEXT
parameterGroups: []
timestamp: Feb 15, 2021, 10:26:44 AM
component: f7-card
style:
noShadow: false
class:
- padding
box-shadow: '=(items[props.item].state === "ON") ? "10px 10px 28px 1px rgba(255,234,5,0.3)" : "var(--f7-card-expandable-box-shadow)"'
background-color: '=(items[props.item].state === "ON") ? "rgb(255,255,255)" : "rgba(228,228,228,0.9)"'
height: 8.5em
min-width: 8.5em
slots:
content:
style:
margin: 0px
padding: 0px
display: flex
align-items: start
slots:
default:
f7: '=(items[props.item].state === "ON") ? "lightbulb_fill" : "lightbulb"'
margin: 0px
padding: 0px
style:
color: '=(items[props.item].state === "ON") ? "rgba(255,234,5,1)" : "gray"'
- component: Label
text: =props.prop1
style:
font-size: 15px
font-weight: 500
margin-left: 0px
margin-top: 20px
padding: 0px
color: '=(items[props.item].state === "ON") ? "black" : "rgba(0, 0, 0, 0.5)"'
- component: Label
text: '=(items[props.item].state === "ON") ? "AN" : "AUS"'
style:
font-size: 15px
font-weight: 500
margin-left: 0px
margin-top: 0px
padding: 0px
color: '=(items[props.item].state === "ON") ? "red" : "rgba(0, 0, 0, 0.5)"'
action: toggle
actionItem: =props.item
actionCommand: ON
actionCommandAlt: OFF
style:
position: absolute
width: 100%
height: 100%
top: 0
left: 0
actionPosition: center
actionFeedback: Done!
uid: widget_f7-card_status_Icon_Battery
tags:
- homekit-like
props:
parameters:
- description: The headline
label: Label-description
required: true
type: TEXT
- description: The size of the Font
label: Font-Size
required: true
type: TEXT
- description: the oh icon name
label: f7 icon name
required: false
type: TEXT
- context: item
description: Status of the Device
label: Status
required: false
type: TEXT
- context: item
description: Battery status of the device
label: Battery
required: false
type: TEXT
parameterGroups: []
timestamp: Feb 9, 2021, 9:05:48 AM
component: f7-card
style:
noShadow: false
class:
- padding: 0px
background-color: '=(items[props.item].state == "OPEN") ? "white" : "rgba(228,228,228,0.9)"'
height: 8.5em
slots:
content:
style:
margin: 1px
padding: 1px
display: flex
align-items: start
slots:
default:
f7: '=(items[props.item2].state === "OFF") ? "battery_100" : "battery_25"'
color: '=(items[props.item2].state == "OFF") ? "green" : "red"'
style:
opacity: 0.5
position: absolute
top: -11px
right: -5px
- component: oh-icon
icon: =props.prop2
height: 38
style:
filter: grayscale()
opacity: 0.7
position: absolute
top: -5px
left: -5px
margin-top: -5px
- component: Label
text: =props.prop1
style:
font-size: =props.fontsize + "px"
font-weight: 500
line-height: 1.1
position: relative
margin-left: 0px
margin-top: 44px
color: '=(items[props.item].state == "OPEN") ? "black" : "rgb(0,0,0,0.5)"'
- component: Label
text: =items[props.item].displayState
style:
margin-left: 0px
margin-top: 2px
font-size: 14px
font-weight: 500
color: '=(items[props.item].state == "OPEN") ? "red" : "rgb(0,0,0,0.5)"'
Thermostate Control with updated orange / green badge for set temperature / color code in case the valve is ON or >15%. Still to be improved in terms of structure of the widget, need more time for proper row-column work, my current workaround is to play with margin and padding… Widget turns white background when some thresholds are reached like temperature or humidity.
uid: widget_f7-card_Temp_V2_Control
tags:
- homekit-look
- Soll Tag
- in use
props:
parameters:
label: Prop 1
required: false
type: TEXT
- description: Thermostate icon f7
label: f7 icon name
required: false
type: TEXT
- description: Humidity icon f7
label: f7 icon name
required: false
type: TEXT
- context: item
description: A Temperature item to display
label: Item
required: false
type: TEXT
- context: item
description: A Set-Temperature item to display
label: Item
required: false
type: TEXT
- context: item
description: An Humidity item to display
label: Item
required: false
type: TEXT
- context: item
description: the valve state
label: Item
required: false
type: TEXT
- context: item
description: Item for temperature channel
label: Ambient temperature
required: false
type: TEXT
- context: item
description: Item for outdoor temperature channel
label: Outdoor temperature
required: false
type: TEXT
- context: item
description: Item for target temperature channel
label: Target temperature
required: true
type: TEXT
- context: item
description: Item for operation mode channel
label: Operation mode
required: true
type: TEXT
parameterGroups: []
timestamp: Feb 17, 2021, 4:03:46 PM
component: f7-card
style:
noShadow: false
class:
- padding
background-color: '=(Number.parseFloat(items[props.itemHum].state.split(" ")[0]) > 60) ? "white" : (Number.parseFloat(items[props.itemTemp].state.split(" ")[0]) > 23) ? "white" : "rgba(228,228,228,0.9)"'
height: 8.5em
min-width: 9.5em
max-width: 400px
slots:
content:
style:
margin-left: -6px
padding: -1px
display: flex
align-items: start
- component: f7-row
class:
slots:
default:
f7: =props.icon1
class:
- align-self-center
style:
margin-left: -6px
margin-top: 0px
color: '=(Number.parseFloat(items[props.itemHum].state.split(" ")[0]) > 60) ? "black" : (Number.parseFloat(items[props.itemTemp].state.split(" ")[0]) > 23) ? "black" : "rgb(0,0,0,0.5)"'
- component: Label
text: =props.prop1
style:
font-size: 14px
font-weight: 500
margin-left: -4px
margin-top: 0px
- component: f7-row
class:
slots:
default:
- component: Label
text: =(Number.parseFloat(items[props.itemTemp].state.split(" ")[0]) * 100 / 100).toFixed(1) + '°'
style:
font-size: 32px
line-height: 1.1
font-weight: 498
margin-left: 0px
margin-top: 0px
- component: f7-row
class:
slots:
default:
f7: =props.icon2
style:
top: 5px
left: 0px
color: '=(Number.parseFloat(items[props.itemHum].state.split(" ")[0]) > 60) ? "red" : "rgb(0,0,0,0.5)"'
- component: Label
text: =(Number.parseFloat(items[props.itemHum].state.split(" ")[0]) * 100 / 100).toFixed(0) + '%'
visible: =props.itemHum !== undefined
style:
top: 5px
left: 0px
font-size: 13px
font-weight: 500
- component: f7-row
class:
- float-right
slots:
default:
f7: arrowshape_turn_up_right
style:
opacity: 0.5
bottom: 0px
right: -45px
color: rgb(0,0,0,0.5)
- component: f7-chip
bgColor: '=(Number.parseFloat(items[props.itemValve].state.split(" ")[0]) > 15) ? "orange" : "green"'
text: =(Number.parseFloat(items[props.itemTempSoll].state.split(" ")[0]) * 100 / 100).toFixed(0)
style:
color: white
z-index: 2
bottom: 75px
border-radius: 25px 25px 25px 25px
margin-top: 2px
right: -5px
- component: oh-trend
trendItem: =[props.itemTemp]
style:
--f7-theme-color-bg-color: transparent
background: var(--f7-theme-color-bg-color)
filter: opacity(30%)
position: absolute
width: 100%
height: 100%
top: 0
left: 2
z-index: 1
action: popup
actionModal: widget:HM_Thermostat_Control_Final
actionModalConfig:
itemAmbientTemp: =props.itemAmbientTemp
itemOutdoorTemp: =props.itemOutdoorTemp
itemTargetTemp: =props.itemTargetTemp
itemMode: =props.itemMode
style:
position: absolute
width: 100%
height: 100%
top: 0
left: 0
Is there a way to do not only tap actions but also hold actions as well for the cards? I tried to search but no luck…
I would love to be able to tap for on/off and if I tap for 2-3 seconds then it opens a popup with detailed controls.
Thank you so much : ) is there a easy way to change the standard “label cells” to the homekit style?
Basically is use the “oh-label-cell” as a switch and to open a nother page.
I tried to insert the style form your widget in the yaml file from the “oh-label-cel”, but nothing changes.
the problem with the oh-label-cell is that it has limitations. specifically if you want to control the bg color other than the standard yellow, green, red… etc.. Also you cannot fully control where to place your content. This is mainly why i have re-created the oh-label-cells with my versions, using a f7-card. So the answer is no, you unfortunately cannot tweak the oh-label-cells with my widgets to make them look alike.
I am still waiting for an answer on this.
I am getting more familiar with the UI development so would be great to design the widgets in a way that I can turn on things with a short-tap and be able to do detailed settings by doing a long-tap.
This is more or less what I’ve been using on Home Assistant (which from I am trying to migrate because of the UI and how easy to develop widgets on OH).
Unless this is possible somehow the only thing I could do is to have an icon (like what @muelli1967 showed a few posts back) on the bottom right and by tapping that open the detailed controls. Long-tap would be better .
Thanks!
Can I find somewhere the code of a pre-made widget-components like ‘oh-image-card’ so that I can create a custom widget based on this code + further adjustments?
The cells have this functionality. You can configure an action on left click/short tap, but it will expand on right click/long tap/click on the 3-dot icon. You can configure what’s in the expanded card by placing additional controls in the default
slot.
The default widgets are made with Vue, not YAML, so you can base yours on them (overriding CSS variables for example) but not modify them.
Thanks @ysc!
Sounds like you’ve just helped me to find something to do in the next couple of days
For others:
Meawhile I found this:
https://github.com/openhab/openhab-webui/pull/317#issuecomment-698252019
This is really helping, this is what exactly I am trying to do.
