Hi Rainer,
I just noticed that the code here for the darkLiquid_card , which looks pretty nice, works fine until you switch on the trendline. In that case
the stepper doesn’t work anymore
the toggle doesn’t work anymore
It seems the trend overlaps the whole widget and therefore covers the controls:
Interestingly the slider works well.
Any idea, why that is the case and how it could be fixed?
winux
(Even)
August 6, 2022, 9:59am
304
Hello, how do i get rid of those circles/dots and dashes ?
They are appearing in between f7-col <-> f7-col and the dashes between f7-row <-> f7-row.
uid: DummyWidget
tags: []
props:
parameters:
- description: Title
required: false
type: TEXT
- context: item
description: Wassertemperatur Item
required: false
type: TEXT
- context: item
description: Umwälzpumpe Item
required: false
type: TEXT
- description: Umwälzpumpe Name
required: false
type: TEXT
- context: item
description: Poolbeleuchtung Item
required: false
type: TEXT
- description: Poolbeleuchtung Name
required: false
type: TEXT
parameterGroups: []
timestamp: Aug 6, 2022, 11:48:49 AM
component: f7-card
title: '=props.title ? props.title : "Set props to test!"'
style:
background-color: '=items[props.pool_temp].state.split(" ")[0] > 24.5 && items[props.pool_temp].state.split(" ")[0] < 27.5 ? "rgba(127,255,0,0.3" : items[props.pool_temp].state.split(" ")[0] > 27.5 ? "rgba(255, 69, 0,0.3)" : "rgba(0,0,255,0.3)"'
box-shadow: 5px 5px 10px 1px rgba(0,0,0,0.1)
padding: 5px
noShadow: false
slots:
default:
- component: f7-row
class:
- justify-content-center
- text-align-center
- no-hairlines
style:
padding-top: 10px
slots:
default:
- component: f7-col
width: 100
xsmall: 33
small: 33
resizableHandler: false
slots:
default:
- component: oh-icon
icon: light
height: 30
- component: f7-col
width: 100
xsmall: 33
small: 33
slots:
default:
- component: oh-label-item
title: '=props.pool_lights_name ? props.pool_lights_name : "Bitte props einstellen"'
style:
font-size: 15px
font-weight: 500
margin-left: 0px
- component: f7-col
width: 100
xsmall: 33
small: 33
slots:
default:
- component: oh-toggle-item
item: =props.pool_lights
style:
transform: scale(1.1)
- component: f7-row
class:
- text-align-center
- no-hairlines
slots:
default:
- component: f7-icon
f7: thermometer
color: red
style:
margin-top: 10px
- component: f7-row
class:
- no-hairlines
slots:
default:
- component: f7-col
width: 100
xsmall: 100
small: 100
slots:
default:
item: =props.pool_temp
style:
text-align: center
font-size: 25px
font-weight: 500
margin-left: 0px
- component: f7-row
style:
padding-bottom: 10px
slots:
default:
- component: f7-col
width: 100
xsmall: 100
small: 100
slots:
default:
title: Wassertemperatur
style:
text-align: center
font-size: 20px
font-weight: 500
- component: f7-row
class:
- text-align-center
- no-hairlines
slots:
default:
- component: f7-col
width: 100
xsmall: 33
small: 33
slots:
default:
icon: pump
height: 30
- component: f7-col
width: 100
xsmall: 33
small: 33
slots:
default:
title: '=props.pool_pump_name ? props.pool_pump_name : "Bitte props einstellen"'
style:
font-size: 15px
font-weight: 500
margin-left: 0px
- component: f7-col
width: 100
xsmall: 33
small: 33
slots:
default:
item: =props.pool_pump
style:
JustinG
(JustinG)
August 6, 2022, 4:02pm
305
All of these appear because you are using the -item
widgets. The item widgets are intended to be used only as the children of a list (oh-list-card
, oh-list
, or f7-list
). If they are placed without a list as a parent you get the improper formatting of the element.
See the docs for the list of components that are available to you and note for for each of the -item
widgets, there’s a regular widget you can use instead without the list formatting issues.*
*- The one exception that is not in the docs is the one for making labels. The widget to use for just placing text, such as an Item state, is Label
which takes only text
and style
properties.
winux
(Even)
August 6, 2022, 7:02pm
306
Thanks you very much! It worked nicely =).
I’m still experimenting.
Cheers
