I’m trying to integrate an old HA system call WebBrick (no longer available).
The devices publish UDP packets over port 2552 when there are changes.
The UDP packet format is
9.1 General UDP Packet format
The UDP Packet Format is formed as follows:
Field Description
Len (byte) The overall size of the UDP packet.
udpType (byte) The packet type one of the characters ‘A’, ‘G’, ‘R’.
Source 0-1 (2bytes) These are two characters to identify the Udp source see later table.
srcChannel (byte) The channel/event index.
tgtChannel (byte) The target channel when sending remote commands, if the target
channel type is analogue then the top bit is set, i.e. values are
128+channel.
action (byte) The action being triggered (low 4 bits), includes Dwell number
(high 4 bits).
fromNodeNr (byte) Source webrick number 1-253.
toNodeNr (byte) Target webrick number for remote commands.
setPointNr (byte) Where relevant for packet type.
curValH (byte) High byte of any value being sent
curValL (byte) Low byte of any value being sentEnter code here…
I’ve set my config up as
#udp spec
udp:itemsharedconnections=true
udp:bindingsharedconnections=true
udp:directionssharedconnections=false
udp:addressmask=true
udp:postamble=
udp:blocking=false
udp:refreshinterval=250
udp:port=2552
I can see the UDP hitting in the logs, but not processing through the channel
GCT\�� on the listener port from /192.168.1.243:4096Binding] - Received
GCT\�� from an undefined remote end /192.168.1.243:4096. We will not process it
2015-07-29 06:23:43.499 [WARN ] [AbstractDatagramChannelBinding] - No channel is active or defined for the data we received from /192.168.1.243:4096. It will be discarded.
My Item is setup as
/* UDP Items /
String MY_UDP_String “Test String[%s]” {udp="<[192.168.1.249:4096:'REGEX((.))’]"}
And a test rule as
rule “Log UDP”
String MY_UDP_String changed
logInfo(“UDP Packet *******************************”)
Any suggestions, or areas that I’m missing ?
Paul
