- Platform information:
- Hardware: Synology
- Java Runtime Environment: 1.8.0.192
- openHAB version: 2.3.0.005
- Issue of the topic: I have a lot of hue lights in my home and recently added some Busch-Jaeger Light Link switches. Setup up a scenario with the switches was easy but I am missing something: I can close shutters at home via openhab and that works fine too. The shutters are connected via z-wave. Via rules I can use the Hue dimmers to close the shutters because I can see the interaction in the log and know how to connect the zigbee dimmer event with the z-wave actor. (I am using the hue bridge).
When I press a button at the Busch-Jaeger switch I can see the change for the bulbs but nothing from the switch. So I have three ideas (maybe both are stupied):
- get a hue compatible outlet (like osrams) and connect it to the switch --> use the outlet and a rule to open/close the shutters
- Setup a zigbee dummy(?) and connect it to the switch.
- add a zigbee usb stick to the zigbee network and hope to be able to see the switch log.
any other ideas?
JP
