Micbla
(Michael Blaas)
May 31, 2021, 7:10pm
#1
Hello community!
Some years ago i implemented my Busch Jäger iNet Radio in OH2.
I do that with the help of @MichaelBormann and his tutorial
Now in OH3 (3.0.2) this solution not run anymore.
Old Items
Number Badradio_Sender "Sender" <radio1> (gBad) { http="<[http://192.168.1.27/de/index.shtml:5000:REGEX(.*Station (.):.*)] >[0:GET:http://192.168.1.27/de/general.cgi?es=1&ss=01] >[*:GET:http://192.168.1.27/de/index.cgi?p%2$s]" }
Number Badradio_Volume "Lautstärke [%d]" <soundvolume> (gBad) { http="<[http://192.168.1.27/de/index.shtml:5000:REGEX(.*size=5 maxlength=5 value=\"(.*?)\".*)] >[*:GET:http://192.168.1.27/de/index.cgi?vo=%2$s] "}
Old Sitemap
Selection item=Badradio_Sender label="Sender:" mappings=[0="RADIO AUS", 1="Rai Südtirol", 2="Antenne Bayern", 3="Discofox FM", 4="Swiss Jazz", 5="Ö3", 6="Sunshine", 7="Chillout Lounge", 8="New York"]
Setpoint item=Badradio_Volume label="Lautstärke:" minValue=2 maxValue=30 step=2```
Someone can help me to solve this issue?
Micbla
(Michael Blaas)
June 22, 2021, 9:32am
#2
Maybe someone can take a look on this topic
hmerk
(Hans-Jörg Merk)
June 22, 2021, 9:38am
#3
Please read the documentation for the openHAB 3 HTTP Binding and try to configure accordingly.
If this does not work, you can show us your config and logs, then someone will shurely step in to help.
But we will not write your config, you should start yourself.
Micbla
(Michael Blaas)
October 4, 2021, 7:39pm
#4
Hello community!
I never learned to program something, only learning by doing.
Because that find the correct configuration from nothing was very hard,
but after days and hours i was able to do it.
Maybe someone with the same radio need the solution…
The code for the webbased http binding configuration
UID: http:url:f68e90cfcc
label: HTTP Badradio
thingTypeUID: http:url
configuration:
authMode: BASIC
ignoreSSLErrors: false
baseURL: http://192.168.1.27/
delay: 0
stateMethod: GET
refresh: 30
commandMethod: GET
timeout: 3000
bufferSize: 2048
channels:
- id: badradio_sender
channelTypeUID: http:number
label: badradio_sender
description: ""
configuration:
stateExtension: de/index.shtml
stateTransformation: REGEX:.*Station (.):.*
commandExtension: de/index.cgi?p%2$s
- id: badradio_volume
label: badradio_volume
description: ""
configuration:
stateTransformation: REGEX:.*size=5 maxlength=5 value=\"(.*?)\".*
commandExtension: de/index.cgi?vo=%2$s
- id: badradio_sleep
label: badradio_sleep
description: ""
configuration:
commandExtension: de/general.cgi?es=1&ss=01
The Items
//--> Badradio
Number Badradio_Sender "Sender:" <radio1> (gBad) { channel="http:url:f68e90cfcc:badradio_sender" }
Number Badradio_Sleep "Sleep" (gBad) { channel="http:url:f68e90cfcc:badradio_sleep" }
Number Badradio_Volume "Lautstärke: [%d]" <soundvolume> (gBad) { channel="http:url:f68e90cfcc:badradio_volume" }
The sitemap
Selection item=Badradio_Sender mappings=[ 1="Rai Südtirol", 2="Antenne Bayern", 3="Discofox FM", 4="Swiss Jazz", 5="Ö3", 6="Sunshine", 7="Chillout Lounge", 8="New York"]
Switch item=Badradio_Sleep mappings=[ 0= "Start Sleep" ]
Setpoint item=Badradio_Volume minValue=2 maxValue=30 step=2
