i love to use the new Buttongrid function.
Is it also possible to use different item for one Buttongrid?
I want to combine different item commands in one Buttongrid.
No. Each sitemap element controls only one item.
You can create a dummy item that receives the command from the buttongrid, then write a rule to dispatch the command to the corresponding item.
Thank you, I would have followed the same approach now.
