ButtonSwitch: button widget to send ON or OFF commands to an item
A simple button widget that sends ON or OFF commands to an item. The labels on the button can be configured, as well as the TITLE and FOOTER.
The widget is based on the OH-documentation from
Screenshots
I use this to control the roller shutter automation in my house:
Changelog
Version 0.1
  • initial release
Version 0.2
  • added quotation marks for the actionCommands
Resources
uid: ButtonSwitch
tags: []
props:
  parameters:
    - context: item
      description: Item to use with this button.
      label: Item
      required: true
      type: TEXT
      groupName: general
    - description: Text to show as title.
      label: Title
      required: false
      type: TEXT
    - description: Text to show as footer.
      label: Footer
      required: false
      type: TEXT
    - description: Text to show on the 'ON' button.
      label: OnButton
      required: false
      type: TEXT
    - description: Text to show on the 'OFF' button.
      label: OffButton
      required: false
      type: TEXT
  parameterGroups:
    - name: general
      label: Display options
timestamp: Jul 4, 2021, 10:03:36 AM
component: f7-card
  title: '=(props.Title) ? props.Title : ""'
  footer: '=(props.Footer) ? props.Footer : ""'
  style:
    min-width: 250px
slots:
  default:
    - component: f7-block
        class: bog
        style:
          display: flex
          flex-wrap: wrap
          justify-content: space-between
          align-content: space-between
          padding: 20px
      slots:
        default:
          - component: f7-segmented
            slots:
              default:
                - component: oh-button
                    text: '=(props.OnButton) ? props.OnButton : "ON"'
                    outline: true
                    action: command
                    actionItem: =props.item
                    actionCommand: "ON"
                    active: "=(items[props.item].state === 'ON') ? true : false"
                    style:
                      width: 100px
                    text: '=(props.OffButton) ? props.OffButton : "OFF"'
                    outline: true
                    action: command
                    actionCommand: "OFF"
                    active: "=(items[props.item].state === 'OFF') ? true : false"
                    style:
                      width: 100px
