Every time I start OpenHAB I get the following error messages, everything is working but I would like to cleanup this error. I believe it happened after I moved the OpenHAB installation folder. Running on Windows 10.
2018-11-01 16:01:45.085 [WARN ] [org.apache.felix.fileinstall ] - C:\OPENHA~2.0\addons does not exist, please create it.
2018-11-01 16:01:45.091 [WARN ] [org.apache.felix.fileinstall ] - Root path does not exist: C:\OPENHA~2.0\addons
I’m not sure about Windows, but in Linux, there’s an OPENHAB_HOME environment variable that specifies the location of the openHAB root directory. I’m not sure where that is set and whether it can be safely changed. Generally speaking, I don’t think it’s advisable to change the root directory after the system is installed.
