I have some temperature sensors. I would like to calculate avarage value from these.
Openhab2 > influxdb > grafana.
Grafana cant calclate avg from different measurements, so I thought that i create a virtual item (avgTemp), and send it to grafana as a series (as normal Item value).
Is this possible?
Or do you have other suggestions for this problem?
openHAB won’t send values directly to the database. You’ll have to add a proxy (=virtual) item for averages. Then update them in a rule everytime one of the real items changes - and add the proxy item to your persistence.
Basically the scenario you described a bit more explained.
Create a Group using the AVG aggregation function and make sure to add that Group Item to your persistence. Add each of your sensors to the Group. Here are my average indoor temps Items and persistence.
Group:Number:AVG gIndoorTemps "Average Indoor Temp [%.0f °F]" <temperature>
Number vNest_Temp "Main Floor Ambient Temp [%d °F]"
<temperature> (gChart, gIndoorTemps)
{ nest="<[thermostats(Entryway).ambient_temperature_f]" }
// gChart causes this Item to be persisted
Number vMBR_Temperature "Master Bedroom Temperature [%.0f °F]"
<temperature> (gChart, gIndoorTemps, gResetExpire)
{mqtt="<[mosquitto:rfm69/uber_sensors/mbr/temperature:state:default]", expire="5m,state=NULL" }
