Sim
(Sim)
#1
Hello to all!
I need to calculate the average position of all rollershutter and then make a decision (if > or < about values).
Here the .items
Rollershutter Rollershutter1 "First [%d %%]" .... { knx = .... }
Rollershutter Rollershutter2 "Second [%d %%]" .... { knx = .... }
…etc…
This is a first step and work correctly (.rules):
if ( Rollershutter1.state > 50 ) {
#ok!
but I need something like this:
if (((Rollershutter1.state + Rollershutter2.state + Rollershutter3.state + Rollershutter4.state) /10) > 50 ) {
I’ve tested different syntax without results
Is is possibile?
Best regards
Sim
rlkoshak
(Rich Koshak)
#2
I think the easiest way to do this is through a Group.
Group:Rollershutter:AVG gAllShutters
The state of gAllShutters will be the average of the states of all its members.
In the Rules, I think your specific problem is that you may need to cast the state to a DecimalType before you can do math with it.
So your math would look like:
val total = ((Rollershutter1.state as DecimalType) + (Rollershutter2.state as DecimalType) + ...
You should be seeing errors in the logs. That should always be the first place to look when you encounter problems.
imhofa
(Andreas Imhof)
#3
There is no need to do maths with your single items. If you need to compare all your shutter items against a threshold just use the gAllShutters.
if ( (gAllShutters.state as DecimalType) > 20)
// in average all shutters are above 20 (percent)
Andreas
