First of all, I think Weather Calculations [4.0.0;4.2.0) can handle this for you. You may not need this rule at all.
Don’t force the types of variables unless and until absolutely necessary. One of the places where it is necessary is when calling Math. functions which all require primitives.
var Temp = (Weather_Station_Outdoor_Temperature.state as QuantityType<Number>).doubleValue
var Humity = (Weather_Station_Humidity_Outside.state as QuantityType<Number>).doubleValue
var T = Temp * 9/5 + 32
var RH = Humity * 100
var HI = 0;
if(T <= 40.0) {
HI = T
} else {
HI = -42.379 + 2.04901523*T + 10.14333127*RH - 0.22475541*T*RH - 0.00683783*T*T - 0.05481717*RH*RH + 0.00122874*T*T*RH + 0.00085282*T*RH*RH - 0.00000199*T*T*RH*RH
if (RH < 13 && T >= 80 && T <= 112) {
var adjust = ((13-RH)/4) * Math.sqrt((17-Math.abs(T-95)/17).doubleValue)
HI = HI - adjust
} else if (RH > 85 && T >= 80 && T <= 87) {
var adjust = ((RH-85)/10) * ((87-T)/5)
HI = HI + adjust
} else if (T < 80){
HI = 0.5 * (T + 61.0 + ((T-68.0)*1.2) + (RH*0.094))
var FeelTemp = (HI - 32) * 5/9
PocitovaTeplota.postUpdate(FeelTemp)
Some other things of note:
Why are you converting to °F manually? Assuming
Weather_Station_Outdoor_Temperatureis aNumber:Temperature, the whole point of units is so that you don’t have to do these sorts of conversions.var T = (Weather_Station_Outdoor_Temperature.state as QuantityType).toUnit(‘°F’).doubleValue
Even better, set the
unitof the Item to°Fand the value will be converted before the Item is even updated. That’s kind of the point of units in the first place. -
Why are you multiplying the humidity by 100? Assuming
Weather_Station_Humidity_Outsideis aNumber:Dimensionless, given this Item represents a percent theunitmetadata should be set to%. Then the value will be between 0-100, not 0.0 and 1.0. And of course you can force it in your rule.var RH = (Weather_Station_Humidity_Outside.state as QuantityType).toUnit(‘%’)
If you’d rather not deal with units in the first place, then don’t use them in the first place. Change your Items to be just
Numberand you won’t have to worry about units. Of course it will be up to you do handle conversions and such yourself if you do that.
