I am trying to do some math again. Looks like I am a bit lost again:
I want to calculate the Coefficient of Performance for my Heatpump:
rule "ESPAltherma.ESPAlthermaCOP"
//ESPAltherma COP Calcualtion
Item ESPAltherma_INVprimarycurrentA changed
if ( ESPAltherma_OperationMode.state == "Heating" ) {
espaltherma_cop.postUpdate(((ESPAltherma_Flowsensorlmin.state as QuantityType<Number>) * 0.06 * 1.16 * (ESPAltherma_LeavingWatertempbeforeBUHR1T.state as QuantityType<Number>) - (ESPAltherma_InletwatertempR4T.state as QuantityType<Number>)) / (ESPAltherma_INVprimarycurrentA.state as QuantityType<Number>) * (ESPAltherma_VoltageNphaseV.state as QuantityType<Number>) / 1000)
The CoP is a number without any unit. How I am suppose to take only number from individual .items to make the formula work?
Hi Ross,
Thanks, yes, I have done that already with VA / W and it is working.
rule "solaredge.ESPAltherma_consumption"
//ESPAltherma COP Calcualtion in kW
espaltherma_consumption.postUpdate((ESPAltherma_VoltageNphaseV.state as QuantityType<Number>) * (ESPAltherma_INVprimarycurrentA.state as QuantityType<Number>))
EDIT: I am trying to do it the “right way”
espaltherma_consumption.postUpdate((ESPAltherma_VoltageNphaseV.state as QuantityType<ElectricPotential>) * (ESPAltherma_INVprimarycurrentA.state as QuantityType<ElectricCurrent>))
The issue with the CoP formula is for example with volumetric flow rate. Mine is in l/min. Is this then correct? ESPAltherma_Flowsensorlmin.state as QuantityType<VolumetricFlowRate>
How the OH will recognize it is in l/min instead of m3/s?
It doesn’t ‘recognize’ any particular units desired, that’s the whole point of quantities really.
It will do V x A or kV x mA and the result might come in mW or kW, who knows.
But who cares either; 1500mW or 1.5W are the same quantity.
Now that’s a bit inconvenient for humans thinking in number terms, we need a way to tell it when we want a quantity represented in some particular unit -
(ESPAltherma_Flowsensorlmin.state as QuantityType<VolumetricFlowRate>).toUnit("°l/min")
it needs to be a unit string known to openHAB, of course
