Because I saw a strange value of a item I added some logging. See below the logging I create every 30 sec.
2022-01-30 23:52:00.213 [INFO ] [nhab.core.model.script.default.rules] - Waarde vastleggen: 7.871 kWh 50.737 kWh 0 kWh 10.274 kWh 5.925 kWh
2022-01-30 23:52:30.215 [INFO ] [nhab.core.model.script.default.rules] - Waarde vastleggen: 7.881 kWh 50.737 kWh 0 kWh 10.274 kWh 5.935 kWh
2022-01-30 23:53:00.211 [INFO ] [nhab.core.model.script.default.rules] - Waarde vastleggen: 7.881 kWh 50.737 kWh 0 kWh 10.274 kWh 5.935 kWh
2022-01-30 23:53:30.232 [INFO ] [nhab.core.model.script.default.rules] - Waarde vastleggen: -4.329 kWh 50.737 kWh 0 kWh 10.274 kWh 5.945 kWh
2022-01-30 23:54:00.214 [INFO ] [nhab.core.model.script.default.rules] - Waarde vastleggen: -4.329 kWh 50.737 kWh 0 kWh 10.274 kWh 5.945 kWh
2022-01-30 23:54:30.215 [INFO ] [nhab.core.model.script.default.rules] - Waarde vastleggen: -4.321 kWh 50.737 kWh 0 kWh 10.274 kWh 5.953 kWh
2
It is all about the first item logged when it changed from 7.881 kWh to -4.329 kWh
The calculation is below. The value in the log files are between {}
ElectraAbsoluutPerWeek.state {7.881 kWh} = SMAAbsoluutPerDag.getStateAs(QuantityType) + ElectraAbsoluutPerWeekReference.getStateAs(QuantityType) {0 kWh} -
ElectraLeveringPerWeek.getStateAs(QuantityType) {10.274 kWh} + ElectraVerbruikPerWeek.getStateAs(QuantityType) {5.925 kWh}
SMAAbsoluutPerDag.state not logged but must be >= 0 kWh and can’t have changed during the evening.
What can be the issue?
