Pi5/8GB(PiOS Lite 64-bit(trixie)/SSD 120GB - OH5.1. openhabian
(Test openHAB 5.2.0-SNAPSHOT - Build #5309 - RPi 5/8 / M.2 SSD)
rule "Datum testen_test"
// Item Dummy_blind changed to "100"
Item Dummy_11 changed to ON
var LocalDate endofCentury = LocalDate.of(2000, 01, 01)
var LocalDate just = LocalDate.now()
var diff = Period.between(endofCentury, just)
logInfo("datediff", "diff between Years: {} Months: {} Days: {} - diff ist {}", diff.getYears, diff.getMonths, diff.getDays, diff)
val heute = now.toLocalDate
val abholTag = (Spring_Start_Met.state as DateTimeType).getZonedDateTime(ZoneId.systemDefault).toLocalDate
val delta = ChronoUnit.DAYS.between(heute, abholTag)
logInfo("datediff-delta", "delta between Years: {} Months: {} Days: {} - diff ist {}", delta)
This Rule calculates the difference of 2 DateTimes and works quit fine in OH5.1.4
Result:
2026-04-19 14:51:31.604 [INFO ] [g.openhab.core.model.script.datediff] - diff between Years: 26 Months: 3 Days: 18 - diff ist P26Y3M18D
2026-04-19 14:51:31.607 [INFO ] [hab.core.model.script.datediff-delta] - delta between Years: -49 Months: {} Days: {} - diff ist {}
In OH5.2.0-Snapshot#5309 the Rule no longer works and shows the following warning-message in the log:
2026-04-19 15:50:09.819 [WARN ] [el.core.internal.ModelRepositoryImpl] - DSL model 'test_datum_test.rules' has errors, therefore ignoring it: [11,23]: no viable alternative at input 'between'
[16,32]: no viable alternative at input 'between'
Does anyone know the reason as I found no clue to fix.
Thx in advance for help.
Cheers - Peter
Lolodomo
(Lolodomo)
April 19, 2026, 2:46pm
2
This is because “between” is a new keyword.
I am working to remove some of these new introduced keywords, including “between”.
And we have found a possible solution to avoid these collisions.
main ← lolodomo:fix_dsl_rule_conditions
opened 09:03AM - 19 Apr 26 UTC
Fix #5488
Fix #5489
Fix #5498
Following keywords are removed: 'uid', 'a', '… between', 'executions', 'but', 'only', 'if'.
'but only if' and 'between executions' are new keywords.
opened 01:30AM - 18 Apr 26 UTC
bug
This problem probably isn't new, but with the recent addition of conditions to D… SL, quite a few new keywords have been created.
In short: In Xtext, any string explicitly defined in quotes (like 'ms') within the grammar becomes a reserved keyword for the entire language. When you use `ms` as a variable name in your script, the lexer prioritizes the keyword `ms` over a general identifier (`ID`).
Although "Data Type Rules" are context-sensitive and will only trigger where other circumstances match (e.g. that you're in a "condition clause"), the defined strings become global keywords.
This effectively "bans" all variable names from matching any of the defined strings. Worse yet, the exception thrown doesn't indicate that this is the cause:
g! org.eclipse.xtext.xbase [org.eclipse.xtext.xbase.jvmmodel.JvmModelAssociator] ERROR : Error calling inferrer
java.lang.NullPointerException: Cannot invoke "org.eclipse.xtext.common.types.JvmField.setStatic(boolean)" because "field" is null
at org.openhab.core.model.rule.jvmmodel.RulesJvmModelInferrer.lambda$2(RulesJvmModelInferrer.java:115)
at org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_doubleArrow(ObjectExtensions.java:141)
at org.openhab.core.model.rule.jvmmodel.RulesJvmModelInferrer.lambda$1(RulesJvmModelInferrer.java:121)
at org.eclipse.xtext.xbase.lib.internal.FunctionDelegate.apply(FunctionDelegate.java:43)
at com.google.common.collect.Lists$TransformingRandomAccessList$1.transform(Lists.java:654)
at com.google.common.collect.TransformedIterator.next(TransformedIterator.java:51)
at org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.operator_add(JvmTypesBuilder.java:139)
at org.openhab.core.model.rule.jvmmodel.RulesJvmModelInferrer.lambda$0(RulesJvmModelInferrer.java:124)
at org.eclipse.xtext.xbase.jvmmodel.JvmModelAssociator$1.run(JvmModelAssociator.java:398)
at org.eclipse.xtext.xbase.jvmmodel.JvmModelAssociator.installDerivedState(JvmModelAssociator.java:408)
at org.eclipse.xtext.resource.DerivedStateAwareResource.installDerivedState(DerivedStateAwareResource.java:244)
at org.eclipse.xtext.xbase.resource.BatchLinkableResource.getContents(BatchLinkableResource.java:149)
at org.openhab.core.model.core.internal.ModelRepositoryImpl.validateModel(ModelRepositoryImpl.java:326)
at org.openhab.core.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:121)
at org.openhab.core.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:109)
at org.openhab.core.model.core.internal.folder.FolderObserver.checkPath(FolderObserver.java:285)
at org.openhab.core.model.core.internal.folder.FolderObserver.processIgnoredPaths(FolderObserver.java:194)
at org.openhab.core.model.core.internal.folder.FolderObserver.addModelParser(FolderObserver.java:103)
at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103)
at java.base/java.lang.reflect.Method.invoke(Method.java:580)
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:245)
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41)
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:687)
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:531)
at org.apache.felix.scr.impl.inject.methods.BindMethod.invoke(BindMethod.java:42)
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:2086)
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:2061)
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:443)
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:336)
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:304)
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1232)
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1152)
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:959)
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:895)
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1184)
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:116)
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:123)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:961)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:937)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:874)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:262)
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:500)
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929)
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915)
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752)
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1274)
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1225)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437)
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:671)
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:310)
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:593)
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:74)
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:460)
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196)
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169)
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49)
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488)
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232)
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:949)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:229)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:499)
at org.eclipse.osgi.container.Module.start(Module.java:486)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:445)
at aQute.launcher.Launcher.start(Launcher.java:699)
at aQute.launcher.Launcher.startBundles(Launcher.java:679)
at aQute.launcher.Launcher.activate(Launcher.java:585)
at aQute.launcher.Launcher.launch(Launcher.java:403)
at aQute.launcher.Launcher.run(Launcher.java:185)
at aQute.launcher.Launcher.main(Launcher.java:161)
at aQute.launcher.pre.EmbeddedLauncher.executeWithRunPath(EmbeddedLauncher.java:170)
at aQute.launcher.pre.EmbeddedLauncher.findAndExecute(EmbeddedLauncher.java:135)
at aQute.launcher.pre.EmbeddedLauncher.main(EmbeddedLauncher.java:52)
The recent addition of conditions have added a number of new such "keywords" that will break existing rules.
Nadahar
(Nadar)
April 19, 2026, 5:17pm
3
In the meanwhile, as a workaround, it should be possible to “escape” keywords with ^, so it should work if you change it to:
ChronoUnit.DAYS.^between(heute, abholTag)
Thx for the hint with the exponent-sign as workaround.
