I am pretty new to openhab and just setting up my first installation. I stumbled across the caldav binding and can not get it to run. In the logs I see following entry as the last message from caldav:
Now I am wondering if there should be also log entries for every connection / refresh of the data from the server which hosts the caldav files. There is nothing to see in the logs at all which shows an activity of the binding.
Besides having issues with the configuration this is mainly for myself trying to understand and troubleshoot the process of this binding.
I don’t use the Personal calenders, only the Command calenders, so am not of any help here.
But everything in the caldavio.cfg needs to start with caldavio:, not with business:
I am not quite sure why, but there were couple of ics-files from a different calendar inside the resource folder. I deleted them and after some time my correct items showed up. Not quite sure what was wrong. Maybe it had something to do with the caldavPersonal.cfg. But I had the entry in there until this morning and deleted it. Nevertheless, thanks for your replies!
But going back to my original question: The only entry I see in the logs is, that my next / current event has changed. No log entry for a connection to the server.
