Hi There,
While starting the caldav-binding I’m getting the following error. It worked for a few weeks and then stopped working.
2019-01-28 20:38:57.766 [ERROR] [org.quartz.core.JobRunShell ] - Job event-reloader.command threw an unhandled Exception:
java.util.ServiceConfigurationError: net.fortuna.ical4j.model.PropertyFactory: Provider net.fortuna.ical4j.model.property.Action$Factory not a subtype
at java.util.ServiceLoader.fail(ServiceLoader.java:239) ~[?:?]
at java.util.ServiceLoader.access$300(ServiceLoader.java:185) ~[?:?]
at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:376) ~[?:?]
at java.util.ServiceLoader$LazyIterator.access$700(ServiceLoader.java:323) ~[?:?]
at java.util.ServiceLoader$LazyIterator$2.run(ServiceLoader.java:407) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:409) ~[?:?]
at java.util.ServiceLoader$1.next(ServiceLoader.java:480) ~[?:?]
at net.fortuna.ical4j.model.AbstractContentFactory.getFactory(AbstractContentFactory.java:85) ~[?:?]
at net.fortuna.ical4j.model.PropertyFactoryImpl.createProperty(PropertyFactoryImpl.java:78) ~[?:?]
at net.fortuna.ical4j.data.CalendarBuilder$ContentHandlerImpl.startProperty(CalendarBuilder.java:326) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl$PropertyParser.parse(CalendarParserImpl.java:206) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl$PropertyParser.access$1100(CalendarParserImpl.java:190) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl$PropertyListParser.parse(CalendarParserImpl.java:173) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl.parse(CalendarParserImpl.java:122) ~[?:?]
at net.fortuna.ical4j.data.CalendarBuilder.build(CalendarBuilder.java:198) ~[?:?]
at org.openhab.io.caldav.internal.job.EventReloaderJob.loadEvents(EventReloaderJob.java:339) ~[?:?]
at org.openhab.io.caldav.internal.job.EventReloaderJob.loadEvents(EventReloaderJob.java:320) ~[?:?]
at org.openhab.io.caldav.internal.job.EventReloaderJob.execute(EventReloaderJob.java:137) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
2019-01-28 20:38:57.875 [ERROR] [org.quartz.core.ErrorLogger ] - Job (event-reloader.command threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
Caused by: java.util.ServiceConfigurationError: net.fortuna.ical4j.model.PropertyFactory: Provider net.fortuna.ical4j.model.property.Action$Factory not a subtype
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
... 1 more
Here is my configuration:
caldavCommand.cfg:
caldavCommand:readCalendars=command
caldavio.cfg:
caldavio:command:url=http://storage.local:5000/caldav/openhab/home.ics
caldavio:command:reloadInterval=1
caldavio:command:preloadTime=20000
caldavio:command:username=openhab
caldavio:command:disableCertificateVerification=false
caldavio:command:password=<secret>
caldavio:command:lastModifiedFileTimeStampValid=false
caldavio:timeZone=Europe/Berlin
Any idea what went wrong?
Bests
Pascal
