Caldav Binding Setup Issue
I’ve tried configuring the Caldav binding and am having some issues. I’m using gmail for my calendar and it is using a custom domain. I’m using OH2 2.1.0-SNAPSHOT build #752 and the Caldav-Personal 1.10.0.SNAPSHOT.
my .items:
String 	currentCalendarEvents		"[%s]"			{caldavPersonal="calendar:'mike' type:'EVENT' eventNr:1 value:'NAME'"}
my caldavio.cfg:
caldavio:mike:url=https://www.google.com/calendar/dav/user@domain.org/events
caldavio:mike:username=user@domain.org
caldavio:mike:password=pass
caldavio:mike:reloadInterval=60
caldavio:mike:preloadTime=20000
caldavio:mike:disableCertificateVerification=true
and without setting up any items or the caldavpersonal.cfg I get this error in the logs:
14:01:01.957 [ERROR] [org.apache.felix.configadmin        ] - [org.osgi.service.cm.ManagedService, org.openhab.io.caldav.CalDavLoader, id=384, bundle=223/mvn:org.openhab.io/org.openhab.io.caldav/1.10.0-SNAPSHOT]: Updating property username of configuration org.openhab.caldavio caused a problem: username must be set
org.osgi.service.cm.ConfigurationException: username : username must be set
        at org.openhab.io.caldav.internal.CalDavLoaderImpl.updated(CalDavLoaderImpl.java:210)[223:org.openhab.io.caldav:1.10.0.201701300211]
        at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[3:org.apache.felix.configadmin:1.8.12]
        at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[3:org.apache.felix.configadmin:1.8.12]
        at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[3:org.apache.felix.configadmin:1.8.12]
        at org.apache.felix.cm.impl.ConfigurationManager$UpdateConfiguration.run(ConfigurationManager.java:1772)[3:org.apache.felix.configadmin:1.8.12]
        at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141)[3:org.apache.felix.configadmin:1.8.12]
        at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109)[3:org.apache.felix.configadmin:1.8.12]
        at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
when rebooting the service this error pops up:
14:33:06.067 [ERROR] [org.openhab.binding.caldav-personal ] - [org.openhab.binding.caldav_personal(195)] The addBindingProvider method has thrown an exception
java.lang.NullPointerException
        at org.openhab.binding.caldav_personal.internal.CalDavBinding.updateItemsForEvent(CalDavBinding.java:225)
        at org.openhab.binding.caldav_personal.internal.CalDavBinding.allBindingsChanged(CalDavBinding.java:134)
        at org.openhab.core.binding.AbstractBinding.addBindingProvider(AbstractBinding.java:61)
        at org.openhab.binding.caldav_personal.internal.CalDavBinding.addBindingProvider(CalDavBinding.java:85)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_121]
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_121]
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_121]
        at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_121]
        at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:224)
        at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39)
        at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:617)
        at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:501)
        at org.apache.felix.scr.impl.inject.BindMethod.invoke(BindMethod.java:655)
        at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1722)
        at org.apache.felix.scr.impl.manager.DependencyManager.open(DependencyManager.java:1556)
        at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:260)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:108)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823)[33:org.apache.felix.scr:2.0.6]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_121]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.apache.felix.metatype.internal.ManagedServiceTracker.addingService(ManagedServiceTracker.java:52)[5:org.apache.felix.metatype:1.1.2]
        at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)[org.osgi.core-6.0.0.jar:]
        at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:]
        at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)[org.osgi.core-6.0.0.jar:]
        at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)[org.osgi.core-6.0.0.jar:]
        at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901)[org.osgi.core-6.0.0.jar:]
        at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:886)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:873)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:940)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:740)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:291)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:429)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:403)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:278)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)[33:org.apache.felix.scr:2.0.6]
        at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)[33:org.apache.felix.scr:2.0.6]
        at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482)[org.osgi.core-6.0.0.jar:]
        at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415)[org.osgi.core-6.0.0.jar:]
        at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232)[org.osgi.core-6.0.0.jar:]
        at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)[org.osgi.core-6.0.0.jar:]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.container.Module.start(Module.java:457)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:392)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:411)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1287)[8:org.apache.karaf.features.core:4.0.8]
        at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:860)[8:org.apache.karaf.features.core:4.0.8]
        at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1176)[8:org.apache.karaf.features.core:4.0.8]
        at org.apache.karaf.features.internal.service.FeaturesServiceImpl$1.call(FeaturesServiceImpl.java:1074)[8:org.apache.karaf.features.core:4.0.8]
        at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_121]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_121]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_121]
any info would be helpful, this has a direct impact on my wife acceptance factor as having the HABPanel in the entryway list the events on the calendar is on her wishlist.
Did you ever get this working?
No, someone else here posted a simple script to grab a calendars data and push it to OH, I’m using that
The post in question, for anyone else who finds this thread is:
setting it up on an hourly executeCommandLine() is working well enough for me, at least until the binding is fixed.
how are you displaying it?
I display it on a dashboard setup using HABPanel, I made a post with the widget source here:
I have the same problem here. Is there an official solution?
Hello Mike,
this is imho a workaround and not a solution.
Regards
Just to state that I have the same error (Nullpointer) but this does not prevent the binding from working.
My items are properly updated with values read from the calendar.
In case it’s not working for you :
  1. check that you don’t have stale caldav config files in:
    /var/lib/openhab2/config/org/openhab
  2. make sure that you have specified the calendar to use in: caldavpersonal.cfg
    For the record, I’m running OH2.2.
    Good luck !
