Hey,
I am completely new to openHAB and this forum, hope I don’t fail too hard for my first topic.
I use openHAB 2.5.5 Release Build on a Raspberry PI 3+ with openHABian.
I configured my Garbage Calendar as a Google Cal and somehow my log gets spammed while an event is active (my local garbage company provided events from 6am to 4pm for the day of collection).
I installed calDAV Personal and Command Binding, but doesn’t use Command at all, if it matters.
I check once a day via cron if there is an event next day and send a message via telegram bot and I have the items in a frame in my Basic UI.
My caldavio.cfg:
caldavio:Muellkalender:url=https://www.google.com/calendar/dav/.../events
caldavio:Muellkalender:username=user
caldavio:Muellkalender:password=password
caldavio:Muellkalender:reloadInterval=60
caldavio:Muellkalender:preloadTime=20160
caldavio:Muellkalender:disableCertificateVerification=true
caldavPersonal.cfg:
caldavPersonal:usedCalendars=Muellkalender
Items (same config for Event 2 and 3):
String CalDAV_Muell_1 "1. [%s]" <calendar> { caldavPersonal="calendar:Muellkalender type:EVENT eventNr:1 value:NAME" }
DateTime CalDAV_Muell_1_Date "Datum der Abholung [%1$td.%1$tm.%1$tY]" <calendar> { caldavPersonal="calendar:Muellkalender type:EVENT eventNr:1 value:START" }
My “problem”:
While an event is active it spams my openhab.log like twice every minute, starting from 6am til 4pm, here is the end:
2020-06-24 15:57:17.486 [INFO ] [nhab.io.caldav.internal.job.EventJob] - event BEGIN for: a6c47ca51c38e4c2d7ee617788ad2a32(Abfuhrtermin Biomüllabfuhr am 24.06.2020@24.06.2020/06:00-24.06.2020/16:00)
2020-06-24 15:58:09.185 [INFO ] [nhab.io.caldav.internal.job.EventJob] - event BEGIN for: ea385c8cea07573991e7bf8ccb97663b(Abfuhrtermin Restmüll am 24.06.2020@24.06.2020/06:00-24.06.2020/16:00)
2020-06-24 15:58:17.111 [INFO ] [nhab.io.caldav.internal.job.EventJob] - event BEGIN for: a6c47ca51c38e4c2d7ee617788ad2a32(Abfuhrtermin Biomüllabfuhr am 24.06.2020@24.06.2020/06:00-24.06.2020/16:00)
2020-06-24 15:59:09.112 [INFO ] [nhab.io.caldav.internal.job.EventJob] - event BEGIN for: ea385c8cea07573991e7bf8ccb97663b(Abfuhrtermin Restmüll am 24.06.2020@24.06.2020/06:00-24.06.2020/16:00)
2020-06-24 15:59:17.064 [INFO ] [nhab.io.caldav.internal.job.EventJob] - event BEGIN for: a6c47ca51c38e4c2d7ee617788ad2a32(Abfuhrtermin Biomüllabfuhr am 24.06.2020@24.06.2020/06:00-24.06.2020/16:00)
2020-06-24 16:00:00.003 [INFO ] [nhab.io.caldav.internal.job.EventJob] - event END for: a6c47ca51c38e4c2d7ee617788ad2a32(Abfuhrtermin Biomüllabfuhr am 24.06.2020@24.06.2020/06:00-24.06.2020/16:00)
2020-06-24 16:00:00.005 [INFO ] [nhab.io.caldav.internal.job.EventJob] - event END for: ea385c8cea07573991e7bf8ccb97663b(Abfuhrtermin Restmüll am 24.06.2020@24.06.2020/06:00-24.06.2020/16:00)
My question: is this normal or expected behaviour?
If not where is the culprit?
Thanks for your help!
Lukas
