2018-06-10 21:10:52.854 [WARN ] [caldav.internal.job.EventReloaderJob] - Sardine error while loading calendar entries: Unexpected response (401 - Unauthorized)
com.github.sardine.impl.SardineException: Unexpected response
at com.github.sardine.impl.handler.ValidatingResponseHandler.validateResponse(ValidatingResponseHandler.java:48) [234:org.openhab.io.caldav:1.12.0]
at com.github.sardine.impl.handler.MultiStatusResponseHandler.handleResponse(MultiStatusResponseHandler.java:40) [234:org.openhab.io.caldav:1.12.0]
at com.github.sardine.impl.handler.MultiStatusResponseHandler.handleResponse(MultiStatusResponseHandler.java:35) [234:org.openhab.io.caldav:1.12.0]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:218) [234:org.openhab.io.caldav:1.12.0]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:160) [234:org.openhab.io.caldav:1.12.0]
at com.github.sardine.impl.SardineImpl.execute(SardineImpl.java:962) [234:org.openhab.io.caldav:1.12.0]
at com.github.sardine.impl.SardineImpl.list(SardineImpl.java:417) [234:org.openhab.io.caldav:1.12.0]
at com.github.sardine.impl.SardineImpl.list(SardineImpl.java:409) [234:org.openhab.io.caldav:1.12.0]
at com.github.sardine.impl.SardineImpl.list(SardineImpl.java:386) [234:org.openhab.io.caldav:1.12.0]
at org.openhab.io.caldav.internal.job.EventReloaderJob.loadEvents(EventReloaderJob.java:246) [234:org.openhab.io.caldav:1.12.0]
at org.openhab.io.caldav.internal.job.EventReloaderJob.execute(EventReloaderJob.java:137) [234:org.openhab.io.caldav:1.12.0]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh230]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh230]
I also get the same 401 unauthorized error with using the v2 API and OAuth. I am using the latest openHAB 2.3 snapshot. Is there a current workable solution using the Google v2 API are we stuck with v1 and insecure apps for the time being?
Sorry, i am not using the Google calendar. I Just tested it maybe 2 years ago.
The warn Message appears every Minute because of the failure.
Your configuration Looks good. Isn’t Somebody Here who is using caldav with Google?
I configured the binding with Google a year ago and it worked with some restriction.
Allow insecure apps in Google configuration.
The configuration is shwon below:
i use this ol topic because I have an issue with the caldav binding.
I configured it and it worked for two days. Now I get an 401 error. But not with the calender I want to use.
I had serveral configurations and I deleted all exept one. This is working. But the errors are from an old configuration that I dont use.
I cleaned the cache with no result.and a restart didnt solve the problem as well.
I had the same problem. Tried to fix it by the hints in the forum. It was not a OH / CALDAV configuration problem but a Google security issue.
I had to allow less secure Apps in my google accout https://myaccount.google.com/lesssecureapps
Now everything is working fine … but with less security
