I’m quite new to OpenHub and the Community here, but there is always the moment in time, were a man need some help ![]()
I did some first steps with some integration of ZWave and MQTT. However, I’m struggling at the moment with CalDav integration, for reading my Nextcloud calender entries. Beside my production environment, I’m using a fresh Openhab docker installation based on Version 2.5.5 for CalDav integration, therefore there is no interference with the before mentioned integration.
So far I followed the instruction in web for CalDAV Personal Binding.
What i did:
- Put “org.openhab.io.caldav_1.8.0.201507310940.jar” file into the addon folder
- Created /openhab/services/caldavio.cfg file with the following content:
caldavio:privcal:url=https://******/remote.php/dav/calendars/******/personal caldavio:privcal:username=***** caldavio:privcal:password=***** caldavio:privcal:reloadInterval=30 caldavio:privcal:preloadTime=1440 caldavio:privcal:disableCertificateVerification=false caldavio:timeZone=Europe/Berlin caldavio:muell:charset=UTF-8
3.) Created a file openhab/services/caldavPersonal.cfg with the following content:
caldavPersonal:usedCalendars=privcal
It seems that the jar file is detected but some dependencies are not resolved, creating the following error:
2020-05-21 10:30:21.957 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/openhab/addons/org.openhab.io.caldav_1.8.0.201507310940.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.io.caldav [237]
Unresolved requirement: Import-Package: org.apache.commons.httpclient; version="3.1.0"
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.4]
2020-05-21 10:30:31.964 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/openhab/addons/org.openhab.io.caldav_1.8.0.201507310940.jar
Does somebody already detected the same issue or has any idea about solution approach?
I already tried to find the missing jar file “org.apache.commons.httpclient” and put it in the addon_folder, but it doesn’t seem to solve the problem.
Any idea is welcome folks !! ![]()
