I have the Caldav Personal binding connecting fine to my Google Calendar. I can see it retrieving the events, and setting up jobs, and the job firing. But there’s no data in my item, and I see nothing in my sitemap.
Any ideas?
Item:
String AtHomeActive “At Home Event Name” {caldavPersonal=“calendar:presence type:ACTIVE eventNr:1 value:NAME”}
Sitemap:
Text item=AtHomeActive label=“[%s]”
Logs (key test event is “Test 3” - others were previous tests):
2018-12-10 14:23:22.168 [DEBUG] [caldav.internal.job.EventReloaderJob] - running EventReloaderJob for config : presence
2018-12-10 14:23:22.173 [DEBUG] [caldav.internal.job.EventReloaderJob] - loading events for config: presence
2018-12-10 14:23:22.178 [DEBUG] [caldav.internal.job.EventReloaderJob] - old eventcontainer – id : 6030ipg8n8tom76jke0q5ljpui@google.com – filename : 6030ipg8n8tom76jke0q5ljpui_google_com – calcuntil : 2018-12-11T14:12:25.454Z – lastchanged : 2018-12-04T22:02:14.000Z – ishistoric : false
2018-12-10 14:23:22.181 [DEBUG] [caldav.internal.job.EventReloaderJob] - old eventcontainer – id : 53rsmjukgf64mqhcf5rf9608oh@google.com – filename : 53rsmjukgf64mqhcf5rf9608oh_google_com – calcuntil : 2018-12-11T14:12:23.610Z – lastchanged : 2018-12-10T13:53:24.000Z – ishistoric : true
2018-12-10 14:23:22.185 [DEBUG] [caldav.internal.job.EventReloaderJob] - old eventlist contains the event : test 2 – deb : 2018-12-10T00:00:00.000Z – fin : 2018-12-11T00:00:00.000Z – lastchanged 2018-12-10T13:53:24.000Z
2018-12-10 14:23:22.189 [DEBUG] [caldav.internal.job.EventReloaderJob] - old eventcontainer – id : 3jg1t353oeqh31dbplgejtu30j@google.com – filename : 3jg1t353oeqh31dbplgejtu30j_google_com – calcuntil : 2018-12-11T14:12:25.903Z – lastchanged : 2018-12-03T14:21:27.000Z – ishistoric : false
2018-12-10 14:23:22.193 [DEBUG] [caldav.internal.job.EventReloaderJob] - old eventcontainer – id : 77a0i12ne4b0j70q5qg0an56dt@google.com – filename : 77a0i12ne4b0j70q5qg0an56dt_google_com – calcuntil : 2018-12-11T14:12:26.346Z – lastchanged : 2018-12-04T17:28:13.000Z – ishistoric : false
2018-12-10 14:23:22.196 [DEBUG] [caldav.internal.job.EventReloaderJob] - old eventcontainer – id : 1gishm5d0nr8s8amcic73t76dk@google.com – filename : 1gishm5d0nr8s8amcic73t76dk_google_com – calcuntil : 2018-12-11T14:12:24.900Z – lastchanged : 2018-12-03T14:20:32.000Z – ishistoric : false
2018-12-10 14:23:22.200 [TRACE] [org.openhab.io.caldav.internal.Util ] - connecting to caldav ‘presence’ (url=https://www.google.com/calendar/dav/dv4qnadfhrsvvsq7oei3kdpaqg@group.calendar.google.com/events, username=david.a.f.gurr)
2018-12-10 14:23:22.971 [TRACE] [caldav.internal.job.EventReloaderJob] - before load events : oldeventids contains : [6030ipg8n8tom76jke0q5ljpui_google_com, 53rsmjukgf64mqhcf5rf9608oh_google_com, 3jg1t353oeqh31dbplgejtu30j_google_com, 77a0i12ne4b0j70q5qg0an56dt_google_com, 1gishm5d0nr8s8amcic73t76dk_google_com]
2018-12-10 14:23:22.975 [TRACE] [caldav.internal.job.EventReloaderJob] - eventContainer found: true
2018-12-10 14:23:22.978 [TRACE] [caldav.internal.job.EventReloaderJob] - last resource modification: 2018-12-10T14:23:22.974Z
2018-12-10 14:23:22.980 [TRACE] [caldav.internal.job.EventReloaderJob] - last change of already loaded event: 2018-12-03T14:20:32.000Z
2018-12-10 14:23:22.982 [DEBUG] [caldav.internal.job.EventReloaderJob] - loading resource: /calendar/dav/dv4qnadfhrsvvsq7oei3kdpaqg@group.calendar.google.com/events/1gishm5d0nr8s8amcic73t76dk@google.com.ics (FSchangedTS not valid)
2018-12-10 14:23:22.984 [TRACE] [caldav.internal.job.EventReloaderJob] - Raw URL: https://www.google.com/calendar/dav/dv4qnadfhrsvvsq7oei3kdpaqg@group.calendar.google.com/events
2018-12-10 14:23:22.987 [TRACE] [caldav.internal.job.EventReloaderJob] - URL after encoding: https://www.google.com/calendar/dav/dv4qnadfhrsvvsq7oei3kdpaqg@group.calendar.google.com/events/1gishm5d0nr8s8amcic73t76dk@google.com.ics
2018-12-10 14:23:23.401 [TRACE] [caldav.internal.job.EventReloaderJob] - loadFrom = 2018-12-10T14:23:23.400Z
2018-12-10 14:23:23.403 [TRACE] [caldav.internal.job.EventReloaderJob] - loadTo = 2018-12-11T14:22:23.403Z
2018-12-10 14:23:23.406 [TRACE] [caldav.internal.job.EventReloaderJob] - loading event: 1gishm5d0nr8s8amcic73t76dk@google.com:At home
2018-12-10 14:23:23.408 [TRACE] [caldav.internal.job.EventReloaderJob] - overriding lastmodified from file FS (2018-12-10T14:23:22.974Z) with event’s last-modified property (2018-12-03T14:20:32.000Z)
2018-12-10 14:23:23.412 [DEBUG] [caldav.internal.job.EventReloaderJob] - Processing event ‘At home’
2018-12-10 14:23:23.414 [DEBUG] [caldav.internal.job.EventReloaderJob] - No periods exist for event ‘At home’
2018-12-10 14:23:23.416 [DEBUG] [caldav.internal.job.EventReloaderJob] - changing eventcontainer last modified to 2018-12-03T14:20:32.000Z
2018-12-10 14:23:23.418 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - event is already in map and not updated, we NEED to update eventlist and schedule new events jobs
2018-12-10 14:23:23.436 [TRACE] [caldav.internal.job.EventReloaderJob] - eventContainer found: false
2018-12-10 14:23:23.438 [TRACE] [caldav.internal.job.EventReloaderJob] - last resource modification: 2018-12-10T14:23:23.435Z
2018-12-10 14:23:23.440 [TRACE] [caldav.internal.job.EventReloaderJob] - last change of already loaded event: null
2018-12-10 14:23:23.441 [DEBUG] [caldav.internal.job.EventReloaderJob] - loading resource: /calendar/dav/dv4qnadfhrsvvsq7oei3kdpaqg@group.calendar.google.com/events/1cp9df7dhk6m3ifg512ebsehj7@google.com.ics (FSchangedTS not valid)
2018-12-10 14:23:23.443 [TRACE] [caldav.internal.job.EventReloaderJob] - Raw URL: https://www.google.com/calendar/dav/dv4qnadfhrsvvsq7oei3kdpaqg@group.calendar.google.com/events
2018-12-10 14:23:23.445 [TRACE] [caldav.internal.job.EventReloaderJob] - URL after encoding: https://www.google.com/calendar/dav/dv4qnadfhrsvvsq7oei3kdpaqg@group.calendar.google.com/events/1cp9df7dhk6m3ifg512ebsehj7@google.com.ics
2018-12-10 14:23:23.968 [TRACE] [caldav.internal.job.EventReloaderJob] - loadFrom = 2018-12-10T14:23:23.968Z
2018-12-10 14:23:23.971 [TRACE] [caldav.internal.job.EventReloaderJob] - loadTo = 2018-12-11T14:22:23.970Z
2018-12-10 14:23:23.973 [TRACE] [caldav.internal.job.EventReloaderJob] - loading event: 1cp9df7dhk6m3ifg512ebsehj7@google.com:Test 3
2018-12-10 14:23:23.976 [TRACE] [caldav.internal.job.EventReloaderJob] - overriding lastmodified from file FS (2018-12-10T14:23:23.435Z) with event’s last-modified property (2018-12-10T14:14:43.000Z)
2018-12-10 14:23:23.981 [DEBUG] [caldav.internal.job.EventReloaderJob] - Processing event ‘Test 3’
2018-12-10 14:23:23.987 [DEBUG] [caldav.internal.job.EventReloaderJob] - Processing periods…
2018-12-10 14:23:23.989 [TRACE] [caldav.internal.job.EventReloaderJob] - start is with known timezone: Europe/London
2018-12-10 14:23:23.991 [TRACE] [caldav.internal.job.EventReloaderJob] - end is with known timezone: Europe/London
2018-12-10 14:23:23.993 [TRACE] [caldav.internal.job.EventReloaderJob] - Processing period 2018-12-10T14:30:00.000Z - 2018-12-11T15:30:00.000Z
2018-12-10 14:23:23.996 [TRACE] [caldav.internal.job.EventReloaderJob] - adding event: 1cp9df7dhk6m3ifg512ebsehj7@google.com(Test 3@10.12.2018/14:30-11.12.2018/15:30)
2018-12-10 14:23:23.998 [DEBUG] [caldav.internal.job.EventReloaderJob] - changing eventcontainer last modified to 2018-12-10T14:14:43.000Z
2018-12-10 14:23:24.001 [TRACE] [.io.caldav.internal.CalDavLoaderImpl] - listeners for events: 1
2018-12-10 14:23:24.003 [TRACE] [.io.caldav.internal.CalDavLoaderImpl] - notify listener… org.openhab.binding.caldav_personal.internal.CalDavBinding@6a9e9f
2018-12-10 14:23:24.005 [TRACE] [.io.caldav.internal.CalDavLoaderImpl] - old start job (event-start-1cp9df7dhk6m3ifg512ebsehj7@google.com(Test 3@10.12.2018/14:30-11.12.2018/15:30)-0) deleted? false/false
2018-12-10 14:23:24.008 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - begin timer scheduled for event ‘1cp9df7dhk6m3ifg512ebsehj7@google.com(Test 3@10.12.2018/14:30-11.12.2018/15:30)’ @ Mon Dec 10 14:30:00 GMT 2018
2018-12-10 14:23:24.011 [TRACE] [.io.caldav.internal.CalDavLoaderImpl] - old end job (event-end-1cp9df7dhk6m3ifg512ebsehj7@google.com(Test 3@10.12.2018/14:30-11.12.2018/15:30)-0) deleted? false/false
2018-12-10 14:23:24.014 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - end timer scheduled for event ‘1cp9df7dhk6m3ifg512ebsehj7@google.com(Test 3@10.12.2018/14:30-11.12.2018/15:30)’ @ Tue Dec 11 15:30:00 GMT 2018
2018-12-10 14:23:24.029 [TRACE] [caldav.internal.job.EventReloaderJob] - eventContainer found: true
2018-12-10 14:23:24.032 [TRACE] [caldav.internal.job.EventReloaderJob] - last resource modification: 2018-12-10T14:23:24.029Z
2018-12-10 14:23:24.035 [TRACE] [caldav.internal.job.EventReloaderJob] - last change of already loaded event: 2018-12-04T22:02:14.000Z
2018-12-10 14:23:24.037 [DEBUG] [caldav.internal.job.EventReloaderJob] - loading resource: /calendar/dav/dv4qnadfhrsvvsq7oei3kdpaqg@group.calendar.google.com/events/6030ipg8n8tom76jke0q5ljpui@google.com.ics (FSchangedTS not valid)
2018-12-10 14:23:24.039 [TRACE] [caldav.internal.job.EventReloaderJob] - Raw URL: https://www.google.com/calendar/dav/dv4qnadfhrsvvsq7oei3kdpaqg@group.calendar.google.com/events
2018-12-10 14:23:24.041 [TRACE] [caldav.internal.job.EventReloaderJob] - URL after encoding: https://www.google.com/calendar/dav/dv4qnadfhrsvvsq7oei3kdpaqg@group.calendar.google.com/events/6030ipg8n8tom76jke0q5ljpui@google.com.ics
2018-12-10 14:23:24.544 [TRACE] [caldav.internal.job.EventReloaderJob] - loadFrom = 2018-12-10T14:23:24.543Z
2018-12-10 14:23:24.546 [TRACE] [caldav.internal.job.EventReloaderJob] - loadTo = 2018-12-11T14:22:24.546Z
2018-12-10 14:23:24.548 [TRACE] [caldav.internal.job.EventReloaderJob] - loading event: 6030ipg8n8tom76jke0q5ljpui@google.com:Test
2018-12-10 14:23:24.551 [TRACE] [caldav.internal.job.EventReloaderJob] - overriding lastmodified from file FS (2018-12-10T14:23:24.029Z) with event’s last-modified property (2018-12-04T22:02:14.000Z)
2018-12-10 14:23:24.554 [DEBUG] [caldav.internal.job.EventReloaderJob] - Processing event ‘Test’
2018-12-10 14:23:24.557 [DEBUG] [caldav.internal.job.EventReloaderJob] - No periods exist for event ‘Test’
2018-12-10 14:23:24.559 [DEBUG] [caldav.internal.job.EventReloaderJob] - changing eventcontainer last modified to 2018-12-04T22:02:14.000Z
2018-12-10 14:23:24.561 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - event is already in map and not updated, we NEED to update eventlist and schedule new events jobs
2018-12-10 14:23:24.568 [TRACE] [caldav.internal.job.EventReloaderJob] - eventContainer found: true
2018-12-10 14:23:24.571 [TRACE] [caldav.internal.job.EventReloaderJob] - last resource modification: 2018-12-10T14:23:24.568Z
2018-12-10 14:23:24.574 [TRACE] [caldav.internal.job.EventReloaderJob] - last change of already loaded event: 2018-12-03T14:21:27.000Z
2018-12-10 14:23:24.575 [DEBUG] [caldav.internal.job.EventReloaderJob] - loading resource: /calendar/dav/dv4qnadfhrsvvsq7oei3kdpaqg@group.calendar.google.com/events/3jg1t353oeqh31dbplgejtu30j@google.com.ics (FSchangedTS not valid)
2018-12-10 14:23:24.577 [TRACE] [caldav.internal.job.EventReloaderJob] - Raw URL: https://www.google.com/calendar/dav/dv4qnadfhrsvvsq7oei3kdpaqg@group.calendar.google.com/events
2018-12-10 14:23:24.579 [TRACE] [caldav.internal.job.EventReloaderJob] - URL after encoding: https://www.google.com/calendar/dav/dv4qnadfhrsvvsq7oei3kdpaqg@group.calendar.google.com/events/3jg1t353oeqh31dbplgejtu30j@google.com.ics
2018-12-10 14:23:24.971 [TRACE] [caldav.internal.job.EventReloaderJob] - loadFrom = 2018-12-10T14:23:24.971Z
2018-12-10 14:23:24.974 [TRACE] [caldav.internal.job.EventReloaderJob] - loadTo = 2018-12-11T14:22:24.973Z
2018-12-10 14:23:24.976 [TRACE] [caldav.internal.job.EventReloaderJob] - loading event: 3jg1t353oeqh31dbplgejtu30j@google.com:At home
2018-12-10 14:23:24.978 [TRACE] [caldav.internal.job.EventReloaderJob] - overriding lastmodified from file FS (2018-12-10T14:23:24.568Z) with event’s last-modified property (2018-12-03T14:21:27.000Z)
2018-12-10 14:23:24.981 [DEBUG] [caldav.internal.job.EventReloaderJob] - Processing event ‘At home’
2018-12-10 14:23:24.982 [DEBUG] [caldav.internal.job.EventReloaderJob] - No periods exist for event ‘At home’
2018-12-10 14:23:24.985 [DEBUG] [caldav.internal.job.EventReloaderJob] - changing eventcontainer last modified to 2018-12-03T14:21:27.000Z
2018-12-10 14:23:24.987 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - event is already in map and not updated, we NEED to update eventlist and schedule new events jobs
2018-12-10 14:23:24.993 [TRACE] [caldav.internal.job.EventReloaderJob] - eventContainer found: true
2018-12-10 14:23:24.996 [TRACE] [caldav.internal.job.EventReloaderJob] - last resource modification: 2018-12-10T14:23:24.993Z
2018-12-10 14:23:24.998 [TRACE] [caldav.internal.job.EventReloaderJob] - last change of already loaded event: 2018-12-04T17:28:13.000Z
2018-12-10 14:23:25.000 [DEBUG] [caldav.internal.job.EventReloaderJob] - loading resource: /calendar/dav/dv4qnadfhrsvvsq7oei3kdpaqg@group.calendar.google.com/events/77a0i12ne4b0j70q5qg0an56dt@google.com.ics (FSchangedTS not valid)
2018-12-10 14:23:25.002 [TRACE] [caldav.internal.job.EventReloaderJob] - Raw URL: https://www.google.com/calendar/dav/dv4qnadfhrsvvsq7oei3kdpaqg@group.calendar.google.com/events
2018-12-10 14:23:25.004 [TRACE] [caldav.internal.job.EventReloaderJob] - URL after encoding: https://www.google.com/calendar/dav/dv4qnadfhrsvvsq7oei3kdpaqg@group.calendar.google.com/events/77a0i12ne4b0j70q5qg0an56dt@google.com.ics
2018-12-10 14:23:25.439 [TRACE] [caldav.internal.job.EventReloaderJob] - loadFrom = 2018-12-10T14:23:25.438Z
2018-12-10 14:23:25.442 [TRACE] [caldav.internal.job.EventReloaderJob] - loadTo = 2018-12-11T14:22:25.441Z
2018-12-10 14:23:25.445 [TRACE] [caldav.internal.job.EventReloaderJob] - loading event: 77a0i12ne4b0j70q5qg0an56dt@google.com:Cotswold break
2018-12-10 14:23:25.449 [TRACE] [caldav.internal.job.EventReloaderJob] - overriding lastmodified from file FS (2018-12-10T14:23:24.993Z) with event’s last-modified property (2018-12-04T17:28:13.000Z)
2018-12-10 14:23:25.453 [DEBUG] [caldav.internal.job.EventReloaderJob] - Processing event ‘Cotswold break’
2018-12-10 14:23:25.456 [DEBUG] [caldav.internal.job.EventReloaderJob] - No periods exist for event ‘Cotswold break’
2018-12-10 14:23:25.460 [DEBUG] [caldav.internal.job.EventReloaderJob] - changing eventcontainer last modified to 2018-12-04T17:28:13.000Z
2018-12-10 14:23:25.463 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - event is already in map and not updated, we NEED to update eventlist and schedule new events jobs
2018-12-10 14:23:25.474 [TRACE] [caldav.internal.job.EventReloaderJob] - after load events : oldeventids contains : [53rsmjukgf64mqhcf5rf9608oh_google_com]
2018-12-10 14:23:25.477 [DEBUG] [caldav.internal.job.EventReloaderJob] - old job (event-start-53rsmjukgf64mqhcf5rf9608oh@google.com(test 2@10.12.2018/00:00-11.12.2018/00:00)-0) deleted? false
2018-12-10 14:23:25.481 [DEBUG] [caldav.internal.job.EventReloaderJob] - old job (event-end-53rsmjukgf64mqhcf5rf9608oh@google.com(test 2@10.12.2018/00:00-11.12.2018/00:00)-0) deleted? true
2018-12-10 14:23:25.485 [DEBUG] [caldav.internal.job.EventReloaderJob] - remove deleted event: 53rsmjukgf64mqhcf5rf9608oh@google.com
2018-12-10 14:23:25.488 [DEBUG] [caldav.internal.job.EventReloaderJob] - jobs scheduled :
2018-12-10 14:23:25.492 [DEBUG] [caldav.internal.job.EventReloaderJob] - [job] : event-end-1cp9df7dhk6m3ifg512ebsehj7@google.com(Test 3@10.12.2018/14:30-11.12.2018/15:30)-0 - [groupName] : event-end - Tue Dec 11 15:30:00 GMT 2018
2018-12-10 14:23:25.495 [DEBUG] [caldav.internal.job.EventReloaderJob] - [job] : presence - [groupName] : event-reloader - Mon Dec 10 14:33:22 GMT 2018
2018-12-10 14:23:25.498 [DEBUG] [caldav.internal.job.EventReloaderJob] - [job] : event-start-1cp9df7dhk6m3ifg512ebsehj7@google.com(Test 3@10.12.2018/14:30-11.12.2018/15:30)-0 - [groupName] : event-start - Mon Dec 10 14:30:00 GMT 2018
2018-12-10 14:30:00.012 [INFO ] [nhab.io.caldav.internal.job.EventJob] - event BEGIN for: 1cp9df7dhk6m3ifg512ebsehj7@google.com(Test 3@10.12.2018/14:30-11.12.2018/15:30)
